11-21-2011, 01:58 PM | #1 |
Drives: 2014 2ss 1le Join Date: Sep 2011
1.25" lowering with 22's?
I want to lower my 2ss with 1.25" drop springs and put on 22" rims. What width and offset should the rims have to safely do this?
And how wide tires could I run? Is it best to stop at 295 in the back or could I go all the way to 315? Thanks! |
11-21-2011, 02:12 PM | #2 |
Drives: 2011 SS/RS Join Date: May 2011
You can run a 315 just fine. My rears are 22x11 with a +38 offset
11-21-2011, 05:07 PM | #3 |
Awesome!
Thanks! |
11-21-2011, 07:05 PM | #4 |
OFF THE CHAIN
Yep i have 22's with 10.5 rears and a +35 offset! You will be fine!
11-21-2011, 08:23 PM | #5 |
AgentJB
You'll be good..
K&N Aircharger // MRT 2.0 // B&G Springs // Custom Wheels // Chrome Bowties // Sinister Hood // Sinister Dovetail Spoiler // Rear CAMARO Badge
11-22-2011, 12:02 AM | #6 |
22s, 315s and 1.25 pfadt drop
11-22-2011, 01:52 AM | #7 |
NM HT5
youll be fine im running 22X10.5 in the rear with a 295 tire and 1.25" eibach drop springs
11-22-2011, 12:54 PM | #8 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
These cars look great with 22" and a 1.25 inch drop. Here is a gallery of a few cars equipped with our drop springs and 22".
11-22-2011, 08:15 PM | #9 | |
FreakyFast!
Drives: 2010 2SS/RS S/C NicKey #55 Join Date: Feb 2011
Drop Srpings
Also, do you know what the rims are in the last Camaro shot you posted? Thanks, FF
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper) Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743 |
11-22-2011, 09:14 PM | #10 |
Evan "FRESHAYR"
Drives: 2014 Stingray Z51, 2014 Jeep SRT Join Date: Mar 2011
22's with a 315 rear tire and dropped 1.25 inches. No problems. You can do it yourself. I just recommend an alignment when you're done with the install.
11-23-2011, 09:47 AM | #11 | |
Drop springs aren't particularly difficult to install, but you will definitely need to get a professional alignment afterwards. As long as you're mechanically inclined and have the proper tools it's not hard. Just make sure you've got a spring compressor or can rent one from your local Autozone to ensure safe dissasembly of your stock shock. If you want to take a look at our instructions including pictures to see what you're getting yourself into you can take a look here: Pfadt Race Engineering Drop Spring Install HowTo |
Thread Tools | |
Similar Threads | ||||
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! | Apex Motorsports | Suspension / Chassis / Brakes | 273 | 04-25-2016 05:17 PM |
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. | Apex Motorsports | Suspension / Chassis / Brakes | 341 | 02-02-2014 11:52 AM |
Lowering Springs w/20's or 22's | DHSS | Suspension / Brakes / Chassis | 6 | 01-24-2011 10:38 AM |
Stainless Works Headers w/BMR Sub Frame Connectors or Lowering Springs under $1375 | Xplosive Performance | V8 Bolt-Ons & Tunes | 2 | 12-30-2010 08:28 AM |
Lowering on 22's? | Gothedoublee | Wheels and Tires Talk Sponsored by The Tire Rack | 16 | 10-20-2010 09:17 PM |
