Old 01-01-2020, 01:54 PM   #1
Chomorro
Drives: 2010 Camaro SS
Anyone rocking an 8" sub in the trunk and happy?
I'm deciding on adding a little bass to the boston system. I have a 12" setup in mind weighs 40lbs all together. Or an 8" setup weighs about 21lbs all together and smaller foot print.
About the same cost for either. Anyone rocking an 8" in the trunk and very happy? I dont need earth shattering bass but I like some thump.
1/12/20 Update
Pioneer powered 10" subwoofer. T harness, 10 gauge amp kit.
Got it installed. Took me a few hours trying to workout cable length etc. I think I still may have made it a little short, the harness was super easy to use. Used blue power cable to ground the amp to the battery but red and black heat shrink to differentiate them. The provided ground was way too short.
I wasnt sure whether to set the sub to speaker level or rca input. Technically its rca input but the harness taps into speaker level if I'm not mistaken.
Also not sure what to tune and set it to so I have some research to do.
It fits perfectly snug under the rear shelf. Going to see if it moves any under driving conditions. Right now it bumps with bass boost at 0 with certain songs. Havent installed the bass knob yet. Ran out of time, the wife needed the garage lol.
Very pleased with this budget bass option so far and I still have the longest part of my trunk of needed.
Thanks everyone for the help!
Sent from my SM-N950U using Tapatalk
Chomorro is offline   Reply With Quote
Old 01-01-2020, 02:17 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
What's your plan for powering your sub, if you don't mind sharing?
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 01-01-2020, 02:19 PM   #3
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
8" is that all you got?
My powered 10" sub won't thump hard but fills in the bass enough to shake the mirrors. I'd get a 12" or more to try to thump.
silversleeper is offline   Reply With Quote
Old 01-01-2020, 02:25 PM   #4
Chomorro
I'm going the easy route and going with a powered 8 or powered 12 enclosure and the ******** harness possibly.
I dont mind separate amps but cost wise this is much cheaper.
Old 01-01-2020, 04:17 PM   #5
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
A all in one 8" won't thump very well , but a high end 8" would hit pretty good. With the right box set up to reflect the bass off the back of the trunk the hit in the front seats would be pretty good.
With today's digital amps can get 500 watts RMS in very very small amp that could easily be mounted in the trunk and not take up any space, like in the spare tire well or on a wheel well or on the sub box it self
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 01-01-2020, 04:41 PM   #6
davidscamaro
https://www.sonicelectronix.com/item...PPO-XL-84.html <sub
https://www.sonicelectronix.com/item...-GM-D8701.html <amp
Just a couple examples of how little money you have to spend to get the bass that will not disappoint. Believe me a all in one 8" will disappoint
Old 01-01-2020, 05:04 PM   #7
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
few weeks ago I installed the Kicker 43DCWR122 (dual 12's) and a 46CXA1200 (1200 watt amp) in another vehicle. I was always skeptical of Kickers and more into Alpine, but the reviews on Crutchfield and Best Buy were great. These things are beasts and not terribly priced. They hit super hard and clean. I doubt the duals would have fit in my Camaro though..
In hind sight, I think I could have gotten away with just a single sub..but I have a new respect for the Kicker line.
StreetRage320 is offline   Reply With Quote
Old 01-01-2020, 05:19 PM   #8
Chomorro
I'm looking at a rockford fosgate powered 8 and JBL powered 12. Probably going to pick the 12 up if it fits the trunk well.
Old 01-01-2020, 07:26 PM   #9
mikeman
Banned
Drives: 2015 Camaro
I have the RF self-powered 10" in mine and it thumps pretty good. It doesn't blast the ghetto, but I wouldn't want it to. I bought it for good bass when I'm in the car and it does just that.
The nice thing is it fits like a glove right under the rear package shelf in the trunk and it doesn't slide around with a little velcro on the top. One of the best mods I've done to date.
mikeman is offline   Reply With Quote
Old 01-01-2020, 07:55 PM   #10
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
I have a 10” Rockford p2 and it hits hard if you want it too.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 01-01-2020, 09:56 PM   #11
Chomorro
I found an rf 8 for $90 used and a jbl 12 for $70 used (ported) but if a 10 works I can get a pioneer 10 within my budget as well.
Thanks for all the input!
Old 01-01-2020, 10:31 PM   #12
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i'm a rockford guy and have been for over 20 years my amps are ovr 20 years old and still rock solid.IMO i would get this if i was on a budget
https://www.amazon.com/Rockford-Fosg.../dp/B00BF6HYDE
i have 2 10's and i replaced the factory radio so no fark for me there are better ways to do what you want. 1 10 is ok for some bass the way i do it 1 12 may be more than you want if you are considering a 8. i just went with sundown 10's to give something else a try.the sundown SA 8's are a great option and take very little air space.
https://www.amazon.com/SA-8-V-3-D4-S...00868620&psc=1 but there are many options you could go with i would go for the best sound takeing the least space.
lemontwist is offline   Reply With Quote
Old 01-01-2020, 10:40 PM   #13
Chomorro
Well I took the plunge. Picked up a 10" powered pioneer, amp kit, thump harness, about $260 total.
I understand the value of better components for the subwoofer but I just have a salty wound after having 3 subwoofer setups stolen in 3 different cars where I went all out.
So cheaper is more appealing these days hahah. I will post up the results when I install it.
Old 01-02-2020, 08:46 AM   #14
xc_SS/RS
Drives: 2010 Camaro SS/RS
Yes - a JL Audio 8-W3v3 in both their ported box and a sealed box
It works but I’d suggest a 10 at least. I’m going with a 12 myself next time
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
