Old 03-13-2018, 07:59 AM   #1
johnjohn
johnjohn's Avatar
Drives: 2010 ss
Holley hi ram install??? What all do you need to cut?
I Won’t to run this intake but not if I have to loose a wiper.
What all is needed to install this? What cutting has to be done?
Thanks John
Pics also if you got them
2010ss L99 to a ls3 s480 turbo lil john cam tuned by james short
johnjohn is offline   Reply With Quote
Old 03-13-2018, 12:08 PM   #2
CGbambam
Drives: 2011 Camaro 2SS
you'll loose the wiper unless you lower your motor by a decent amount or cut the bottom part of the intake to make it shorter
CGbambam is offline   Reply With Quote
Old 03-14-2018, 11:05 AM   #3
Punisher_ATX
Drives: 2010 SS
Can confirm you lose the wiper. Period. Its on the passenger side so idc anyways haha
Punisher_ATX is offline   Reply With Quote
Old 03-14-2018, 12:11 PM   #4
johnjohn
johnjohn's Avatar
Drives: 2010 ss
Got any pics?
Old 03-15-2018, 08:54 AM   #5
BradySS
Drives: 2010 Camaro 2SS
Wipers and motors already removed but any pictures of cutting you had to do I'd love to see. Nitrous Outlet is making me a Hi-Ram direct port setup.
BradySS is offline   Reply With Quote
Old 03-15-2018, 09:19 AM   #6
Punisher_ATX
Drives: 2010 SS
Ill get pictures tonight of what i had to cut.
Old 03-15-2018, 01:46 PM   #7
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I said f it and cut the whole cowl out
ttshovel is offline   Reply With Quote
Old 03-15-2018, 01:58 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Here's mine. Unless you get creative with the passenger side arm linkage or mount a second motor, you will lose the passenger side arm. NRE in CA built a white one and mentioned they kept the passenger side arm by modifying the linkage but didn't go into much more detail. You won't miss it unless you drive in the rain. Even then, Rain X helps tremendously.
Old 03-15-2018, 02:09 PM   #9
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
You guys have to cut the hood at all? And what throttle body?
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 03-15-2018, 02:18 PM   #10
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You'll need to cut your hood or get a cowl hood. I am using an LS2 TB. LS3 also works.
Old 03-15-2018, 02:26 PM   #11
AGP Turbo
Drives: All things Turbocharged
So many other intakes do fit guys. Just saying.
AGP Turbo is offline   Reply With Quote
Old 03-15-2018, 10:01 PM   #12
ozzy1le
ozzy1le's Avatar
Drives: 2015 camaro 1le
Beautiful car Blake b
ozzy1le is offline   Reply With Quote
Old 03-16-2018, 05:11 PM   #13
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
I agree with AGP!!! Both of you have beautiful cars!!! I guess if you are looking for that last bit of horsepower you gotta do what you gotta do. I drive mine over 10,000 miles a summer so this is the route I went. No cutting!! Lol
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 03-17-2018, 11:45 AM   #14
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Who is that one made by?
And how about MSD Atomic Airforce intake?
http://www.superchevy.com/how-to/eng...le-ls-bolt-on/
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned|
God is too good! I don't deserve it, but I sure will accept it!!!
ZX1truth is offline   Reply With Quote
