06-05-2014, 06:15 PM | #1 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
Where is socket head oil galley plug?
While trying to make way on my turbo install for my turbonetics automatic kit I ran across these instructions:
3. Remove the accessory belt from the alternator. 4. Remove the battery cable from the alternator and lower out of mount. 5. Remove the socket head oil galley plug from the side of the engine block. Does anyone know how to do step 5, need help ASAP! Last edited by DaFisch; 06-05-2014 at 06:15 PM. Reason: Forgot to add in question. |
06-05-2014, 07:16 PM | #2 |
By the look in the picture and the description in the instructions, it's behind the alternator toward the bottom front drivers side of the engine block.
06-05-2014, 07:31 PM | #3 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
I think it's where that 90 degree fitting is. You take the plug out and install the 90 degree fitting
2011 2SS/RS built 8/24/10
06-05-2014, 08:20 PM | #4 |
I found the bolt, does anyone have a guide on how to remove the alt? I removed the three bolts but it did nothing
06-05-2014, 08:36 PM | #5 |
Drives: 2011 SS/RS Join Date: Apr 2011
There is no need to remove the alt to install the new plug and fitting. If I remember right, I removed the bottom 2 bolts and swiveled it out of the way when I installed mine.
06-05-2014, 09:50 PM | #6 |
Kyle I have no idea how, i disconnected everything and undid all three bolts and it doesn't move
06-05-2014, 10:46 PM | #7 |
Drives: 2009 ZR1 Join Date: May 2010
Go to vortech's site and download the instructions for installing one of their units (specifically the Ysi). It details, very well, about how to remove the alternator.
06-08-2014, 03:54 PM | #8 |
Drives: 98 Camaro race car Join Date: Feb 2014
there is a 4th bolt thats under where the head gasket would be up above that plug your trying to get to, should be a 15mm bolt that goes into the side of the block that supports the alternator.
11 2SS/RS M6 IOM Polluter'd
98 Camaro LSX Real Street 8.14 at 169 08 Cobalt SS/TC 310whp 06 Duramax LBZ EGR! 4" straight, DSP5 |
