12-07-2016, 11:28 AM | #1 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
JRE Smooth Idle Cam Dyno Results...
Dynojet w/ SAE correction 91 octane -300 DA AFR 10.8-11.2 (have in car wideband) https://youtu.be/CKfUsGLC9f4 2014 ZL1 Auto w/ Stock Converter JRE Cam 22% Lower Pulley Vmax TB Rotofab CAI ARH 1-7/8 LT w/ Cats ID850s w/ BAP Super happy with the results, car runs great... need to Flex Fuel though. Last edited by Crash76; 12-07-2016 at 12:25 PM. |
12-07-2016, 06:55 PM | #2 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Really seems kinda low for a 22% pulley and cam. I would expect mid to high 600's
Bryan 2018 ZL1 M6
12-07-2016, 07:31 PM | #3 |
Team 913
Sent Ted the info, he said he is 100% sure the car is making well over 600... he mentioned it looked like the dyno wasnt reading the rpm properly...
Have to wait and see how it tracks i guess... Last edited by Crash76; 12-07-2016 at 10:42 PM. |
12-07-2016, 07:38 PM | #4 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Would have been over 600 if power kept going up looks maybe it's breaking up top of the graph
12-07-2016, 11:47 PM | #5 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
[QUOTE=ZO6 Bryan;9443765]Really seems kinda low for a 22% pulley and cam. I would expect mid to high 600's[/QUOTION
I'd think mid 600 also. The top of graph doesn't look rite. Maybe belt slippage. Also what rpm we're you at. But good luck
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
12-08-2016, 02:24 AM | #6 |
Team 913
Think it went up to 6700... will have to check
12-08-2016, 06:23 AM | #7 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Belt slip in the upper rpm range, looks just like one of my old graphs when my belt was slipping, fix that and it will make over 600rwhp easy.
12-08-2016, 07:00 AM | #8 |
There are several things in play here.
1) 91 octane 2) tune is not finished, both rich 11.0-11.2 and low on timing until we got a measurement on the dyno. 3) 3 pulls back to back with no cool down. 4) The graph is choppy indicating a common problem with using spark for an RPM signal. Boost was consistent 185 Kpa with no signs of belt slip and Zero KR. We have made 725 RWHP with this cam so don't read to much in to this. I have viewed the logs and sent a revision both pulling fuel and adding timing. Thanks for looking out guys I appreciate the support. Ted.
www.jannettyracing.com
12-08-2016, 07:59 AM | #9 |
Team 913
12.3lb of boost ...
12-08-2016, 09:55 AM | #10 |
Get some meth or e85 that 91 is crap
12-08-2016, 09:50 PM | #11 |
Team 913
Yes, santa has a dsx flex fuel kit on his list
12-08-2016, 10:19 PM | #12 |
Crash76, if Teds involved ur in very good hands my friend. I'm sure all is fine. Enjoy
12-09-2016, 01:33 AM | #13 |
Team 913
He is my goto for this car...
12-09-2016, 04:54 PM | #14 |
Mine too my Chevy dealer did S/C swap and Jannetty's has been the only one to touch my car besides myself. I got no complaints what so ever.
