Old 07-18-2015, 12:39 PM   #43
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Look at the diagram on the panel door. It's like F17 I think. It's the 12v source for the console (it's located between the two relays).
EDIT: F17 > http://www.camaro5.com/forums/showth...install&page=6
JimE is offline   Reply With Quote
Old 09-14-2015, 05:55 PM   #44
CoveyZL1
CoveyZL1's Avatar
Drives: 2014 Camaro ZL1 "SIM" M6 650rwhp
@ZL1-PA... What length of mirror tap do you need to run for the airbag tap?
CoveyZL1 is offline   Reply With Quote
Old 09-15-2015, 07:46 PM   #45
sberk1012
sberk1012's Avatar
Drives: 2013 ZL1 A6
I installed this using airbag light as done by ZL1-PA
You will want the 15"
When I bought the product, this is the length the company recommended for this exact installation and it works great
sberk1012 is offline   Reply With Quote
Old 09-15-2015, 09:58 PM   #46
CoveyZL1
CoveyZL1's Avatar
Sounds good, will be ordering very soon
Old 01-19-2016, 08:17 PM   #47
spike1202
spike1202's Avatar
Drives: 2015 2LT/RS Camaro Convertible
2015 Convertible
Any input available for getting to the airbag light assy in a convertible? The light is above the console and not in it on mine.
spike1202 is offline   Reply With Quote
Old 04-03-2016, 12:58 AM   #48
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
2016 Camaro? Hoping easy mirror tap switchable
2016 Camaro HBM A8, 2SS, NPP, Sunroof, Kalahari Interior/kneepads, Black bowties, 56v:
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
-Oracle ghosted LED sidemarkers
Adrian97c is offline   Reply With Quote
Old 07-31-2017, 09:52 AM   #49
woyster_13ss
woyster_13ss's Avatar
Drives: 2013 IOM 2SS
How long mirror tap cable is required if I were to use the airbag light on my 2013, but use the suction cups to mount my Valentine 1 on the left side of the mirror?
Ordered 4/24/2013...Built week of 5/13/13...Delivered 6/7/13
2013 Inferno Orange Metallic Chevrolet Camaro 2SS/RS
6.2L V8, NPP, Manual 6-Speed, GM Performance Shifter, Cold Air Inductions CAI, Bo White's Stage III Ported TB, Sunroof, Window Tint, Gen5DIY Halo & DRL Harnesses, 5000k LED DRL Bulbs, APEX Skip Shift Eliminator, Hood Spears / Front & Rear Blackout Panels / Gills from Big Worm Graphix, Gary's Customz Front & Rear Painted Bowties, Powdercoated Wheels & Camaro Badges, Painted Calipers, Plastidipped Taillight Bezels
woyster_13ss is offline   Reply With Quote
Old 07-31-2017, 10:26 PM   #50
Leo72793
Drives: 2011 2SS/RS
Originally Posted by epstein View Post
Why not just run your own switched 12v? Its not that involved.
how TF did you do that?
Leo72793 is offline   Reply With Quote
Old 08-10-2017, 06:20 PM   #51
woyster_13ss
Originally Posted by ZL1-PA View Post
All you have to do is remove the roof console via the light, 2 screws and 4 pull out connectors, then run the wire easily by removing the cap over the existing miss or wires, and up thru the headliner. Connect to the RED and BLACK wires, put a wire tie on it, then reassemble.
You can test first to make sure you have a good connection by turning the ignition on and waiting to see if the radar detector turns off and on.
This is an installation on my 2014 ZL1 - red rock.
The 2nd last photo shows how you run the wire thru the headliner.
The last photo shows where the wire lands before you put the mirror wire cap back on.
None of this May make sense or you may not be able to tell what the pictures are until you have yours apart.
Enjoy
Hard-wired my V1 today to the airbag light per the above using the Hidden Mirror Cord from Safe-N-Sound1 (http://www.safe-n-sound1.com/Valentine%20DC%20HM.html).
Old 02-26-2018, 06:33 AM   #52
Zl1TopLess
Zl1TopLess's Avatar
Drives: 2013 Victory Red ZL1 M6 Vert
What mirror tap size are you using? You know the actual pin size?
Seems the wire length is 15" is best suited but what about the insert pins?
Thanks,
2013 ZL1 M6
Roto Fab CAI, Kooks Long tube Headers with catless connection pipes, 90mm Ported throttle body to match ported supercharger snout. 2.55 upper pulley, Roto Fab intercooler tank, ID 850 injectors, 9.5 mm wires, Custom 93 octane tune. 600 whp. Hotchkis coils.
White Collar Grease Monkey
https://www.youtube.com/user/gjodexter
Zl1TopLess is offline   Reply With Quote
Old 03-25-2018, 03:04 PM   #53
JimE
JimE's Avatar
That's a 3rd party mirror I do believe. I've seen a few providers for various sources (such as cameras), but I don't recall names atm.
2013 camaro, blendmount, mirror
