Old 12-21-2013, 10:26 PM   #1
sean69cam
sean69cam's Avatar
Drives: 69 camaro, 2013 ss ls3
poly rear cradle bushings, any regrets?
I am debating bmr full poly(not the inserts) vs solid aluminum(pfadt, adm). I am concerned about road noise since this is my daily, so leaning toward the poly bushing. However, I plan on 600whp in the near future and wonder how well the poly holds the cradle on hard acceleration. Anyone with poly later wanted to go solid aluminum?
sean69cam is offline   Reply With Quote
Old 12-22-2013, 01:55 AM   #2
SlowTurtle
Drives: camaro turtle
poly works fine. if some some inane reason you wanted to get aluminum later, you can still sell the polys you have, and its a 5 minute bushing swap once you have aftermarket stuff in there.
This nick no longer in use. Please direct all future pms to 'Dietcoke'
SlowTurtle is offline   Reply With Quote
Old 12-22-2013, 07:02 AM   #3
Bo White
Bo White's Avatar
I have BMR full bushings and 580-600 depending on dyno. It does fine but I've never ridden in one with solid bushings.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-22-2013, 08:39 AM   #4
Synner
Drives: cars
I have full poly and am going solid as soon as I can get the time to install. There isn't any added noise with aluminum. The motor mounts and pro differential bushings are where noise/vibes gets added.
Old 12-22-2013, 09:02 AM   #5
ssmike
BL1ZZRD
ssmike's Avatar
I have Pedders full poly and so far so good, although I'm not pushing 600 hp either! I would go solids with that kind of power.
Old 12-22-2013, 10:08 AM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
There is really no downside to rear cradle bushing upgrades. Even with solid rear cradle bushings the increase in NVH is barely noticeable and completely appropriate for daily driver use. For the kind of power levels you are shooting for solid is the way to go. Do it right and do it once.
Old 12-22-2013, 10:33 AM   #7
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
This.
Solid all the way. I'm shooting for 500rwhp and aren't even considering poly bushings for my daily driver.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 12-22-2013, 03:37 PM   #8
SlowTurtle
my car's run a 1.3 60 foot on stock bushings. I have poly in there now, but it isn't the end-all be-all of suspension mods.
Old 12-23-2013, 07:49 AM   #9
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
I have full Polly's (not pedders) and im probably going with pfadt solids in the near future. My buddy's have them and notice no noise and excellent performance.
I had issues with my cars suspension im at 499/557 on teds heartbreaker superflow dyno, im not sure if its the subframe bushings , most likely a toe link bushing but I'm most likely going to replace all of it and hopefully be done with it.
For your plan I would just go solids now
600 daily your my kind of person nice !
1969to2010 is offline   Reply With Quote
Old 12-23-2013, 03:23 PM   #10
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
With that kind of power, I would not even consider anything less than a solid bushing. There is not much NVH to speak of and beside the initial cost, there is no downside of going with a full bushing.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 12-23-2013, 11:12 PM   #11
sean69cam
sean69cam's Avatar
Thanks guys, going solid bushings. Now have to decide on adm or pfadt. I have a few other pfadt products and like their quality but the adm ones come in at a lower cost
Old 12-24-2013, 07:04 AM   #12
Motion427
Drives: 2010 2SS/RS Red Jewel L99
We did a M6 Camaro that put down 615rwhp the other day.
I drove it before and after the installation of solid cradle bushing.
Noticed a big difference in handling,but I did not notice any increase in NVH.
Great mod.
Motion427 is offline   Reply With Quote
