Old 11-12-2013, 08:07 PM   #1
DarkCry956
DarkCry956's Avatar
Drives: 2011 Camaro 2SS/RS
Trans cooler with Vortech FMIC
Just thought id share this since I looked all over and didn't find much. I used a B&M cooler part # 70274. My trans builder recommended a cooler that was at least 28000 BTU. This cooler is 29000 BTU and is large. Most other coolers I looked at were not even close.
DarkCry956 is offline   Reply With Quote
Old 11-12-2013, 08:10 PM   #2
DarkCry956
DarkCry956's Avatar
On the front facia I had to cut 3 clips that hold a wiring harness for the daily running lights and I tied them out of harms way. Other than that the front facia went right on.
Old 11-12-2013, 08:12 PM   #3
DarkCry956
DarkCry956's Avatar
About to drill the holes to bolt it onto the bolts already in the upper part by the hood latch.
Old 11-12-2013, 08:19 PM   #4
DarkCry956
DarkCry956's Avatar
I could've drilled and made the bracket completely bolt on but I decided to weld it to the bumper instead.
Old 11-12-2013, 08:24 PM   #5
DarkCry956
DarkCry956's Avatar
Old 11-12-2013, 08:25 PM   #6
DarkCry956
DarkCry956's Avatar
Clearance between the intercooler and trans cooler
Old 11-12-2013, 08:28 PM   #7
DarkCry956
DarkCry956's Avatar
You can see just the just the bottom part is in the bumper. I doubt that will have any negative effects
Old 11-13-2013, 07:50 AM   #8
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Let me know what your trans temp is running after this. What size stall?
K32 Camaro is offline   Reply With Quote
Old 11-13-2013, 08:11 AM   #9
DarkCry956
DarkCry956's Avatar
It'll be between 3500 and 4000 stall on a 4L80 and I will be running it alone without the radiator. It will be a while before I get to run it since I don't have a rearend yet and I'm leaving for work. I'll update this as I go
Old 11-13-2013, 10:12 AM   #10
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Nice work
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 11-13-2013, 02:39 PM   #11
DarkCry956
DarkCry956's Avatar
Originally Posted by MANNYS2SS/RS View Post
Nice work
Thanks
