07-26-2017, 02:53 AM | #1 |
Drives: 2018 1ss 1le Hyper Blue Metallic Join Date: Jun 2017
On the road flat fix
What do you guys do when you're on the road and have a flat? I plan on getting a better compressor than what comes with the car. I was wondering what jack to use. Harbor Freight 1 1/2 ton racing jack? Its light weight. Or just get a scissor jack and a Dr. Roc adapter to use with a rachet or a 12volt impact? I don't want to use the slime. I am gonna plug if I ever have too.
07-26-2017, 07:21 AM | #2 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I bought a plug kit, the OEM compressor will air the tire up just fine. I plan on just rolling the tire over to where I can remove the offending item and put the plug in it and air the tire back up.
07-26-2017, 11:07 AM | #3 |
Drives: 2018 1LS 1LE Join Date: Jun 2017
But what if it's sidewall damage from a pothole? I've had that happened to me about two years ago :( luckily I was about two miles from home so I just limped the car super slow back to the house.
I'm just about to order a Camaro - they all come with an oem compressor? Is it in the trunk? |
07-26-2017, 12:03 PM | #4 |
No, if it is a regular SS they come with run flat tires. Only the 1LE models get the compressor and slime.
I think the Camaro SS gets roadside assistance as well for a non-repairable flat. Also most of the run flat tires and I know Continental and Michelin both tow up to 150 miles due to a flat. |
07-26-2017, 01:17 PM | #5 | |
I had RF tires on my current car, and switched out to regular tires once the old ones wore out. The car's ride quality improved for sure with the regular tires. I was planning to do something similar with the 1LE. |
07-26-2017, 02:33 PM | #6 |
Good info to know.
2017 Camaro SS 1LE
07-26-2017, 11:41 PM | #7 |
TJay74. How is there enough room to remove object and install plug? Surely you are jacking car up? What jack do you use?
07-27-2017, 07:56 AM | #8 | |
I have no intentions of carrying a jack in the trunk. |
07-27-2017, 12:31 PM | #9 |
Drives: 2017 Camaro SS 1LE Join Date: Jan 2017
That's what I do on my Volt and plan to do with this car. A plug kit and rubber cement is only a few bucks and will solve most of your problems or at least let you limp home. I just don't feel like spending the cash and extra weight on a spare and jack.
07-27-2017, 02:40 PM | #10 |
Drives: None Join Date: Nov 2016
This is also what I am doing. Plug kit, a piece of chalk, gloves, pliers are all in the trunk just in case.
-Brian
Hyper Blue 1SS / 1LE |
07-27-2017, 03:13 PM | #11 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
As soon as I ditched the run flats, I started to carry a plug kit. I have almost all the pieces needed to build a small (20oz.) CO2 tank to mount in the trunk to refill once I plug the tire. If it's a bad blowout, I can always call roadside assistance under my warrantee or my insurance.
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
07-27-2017, 05:20 PM | #12 |
Why not use a can of fix-a-flat? has anyone had experience with it?
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard 3000 - 08/16/2017 | 4200 - 09/18/2017 shipped! 3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done 3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up! 4300 - 09/12/2017 Built! VIN available 4B00 - 09/14/2017 move to rail yard |
07-28-2017, 07:26 AM | #13 |
07-28-2017, 08:42 AM | #14 |
The only two flats I've experienced were both on the shoulder where the inflator sealant came out and wouldn't seal. I would imagine fix a flat doing the same. Spend the two bucks and throw a cheapo plug kit in your car for another option. It's too light and cheap not to have one in every ride you own.
