Old 08-09-2017, 03:20 PM   #1
Nightfall gray ghost
Nightfall gray ghost's Avatar
Drives: 2014 ZLI Camaro
Shift light
I am currently doing a major engine mod on my 14 ZLI, and while my car is down I wanted to know if there is a shift light built into the system or, do I need to add an external one?
2014 ZL1 with CA I, Ligenfelter ported and polished heads and supercharger, custom hydraulic roller cam, and valves, and springs, 2.55 blower pulley, custom crank pulley, upgraded fuel injectors with booster pump, American Racing long tubes headers with full Borla Atak exhaust system, Autometer digital boost and wide band gauges,custom tune, and some powder coating and airbrushing under the hood for some "splash".
Last dyno, 610whp without nitrous. Nitrous Outlet blower plate system tune: 755 whp on a loaded dyno.
Nightfall gray ghost is offline   Reply With Quote
Old 08-09-2017, 08:26 PM   #2
San2cci
San2cci's Avatar
Drives: 2013 silver ice metallic ZL1
Not sure if this helps but The automatic has a shift indicator built into the HUD in one of the settings. It only works when using the manual mode with the paddle shifters and when you are really getting on it and riding the gears out.
San2cci is offline   Reply With Quote
Old 08-09-2017, 08:29 PM   #3
OneBadvATE
OneBadvATE's Avatar
Drives: 2015 Camaro ZL1
My 2015 M6 ZL1 has it in the HUD when displaying the speed and g-meter. It appears as green arrows facing inward from left and right and as you rev up it gets closer to the middle from both sides and will turn red when it's time to shift. I don't see a need for a secondary light.
2015 Camaro ZL1 - 769RWHP 755RWTQ Mods: RPM 5" intake, Kooks 2" headers w/o cats, 9.1" lower, 2.55" upper, Kong performance ported blower/snout, NW 102mm TB, afco hx w/ fans, RPM cam package, ID1050x injectors,160 degree t-stat, Tuned by Fran at RPM
Best 1/4 mile: 10.99@127
Dyno graph
YouTube
2003 C5 Z06 - SOLD Mods: 455 RWHP 415RWTQ FBO and FTI Street Sweeper Cam (236/240 .631/.612 111 lsa)
OneBadvATE is offline   Reply With Quote
Old 08-09-2017, 08:31 PM   #4
San2cci
San2cci's Avatar
The 15 HUD displays different colors? Mine only displays one color. That's pretty neat.
Old 08-09-2017, 08:40 PM   #5
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Concur - the ZL1 HUD rules. I can't understand for the life of me why they didn't do something similar for the SS cars.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 08-09-2017, 08:41 PM   #6
OneBadvATE
OneBadvATE's Avatar
Correct, the display is in color. I am not sure if that is a 14-15 only feature though.
Dyno graph
YouTube
Old 08-10-2017, 10:00 AM   #7
gbu27
Drives: 2013 ZL1
Color HUD is 14-15. They sell them at gen5diy, I've been tempted to put one in my 13
gbu27 is offline   Reply With Quote
Old 08-10-2017, 12:16 PM   #8
GONMAD510
Drives: 2013 ZL1 M6
Has anyone used the 1 from gen5diy? I would like to know if it is hard to change out.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 08-10-2017, 01:25 PM   #9
So, how do I "turn on" the shift light? Or is it on only in sport mode? And who sets the shift points?
Mine is the T56 top loader transmission. I did not see ny arrows in my hud. Mine is a 2014.
Old 08-10-2017, 08:46 PM   #10
OneBadvATE
OneBadvATE's Avatar
Not sure if it is mode specific, I always drive in PTM4. To my knowledge it shows up when the rpms get above like 4k and you can't change the shift point.
Dyno graph
YouTube
Old 08-11-2017, 10:00 AM   #11
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
When I had my manual Z, it would only work if you were working the car. If you eased up though the gears like normal highway on ramp merging, zip.
No lift shift up the ramp, you get shift lights.
NVRL8 ZL1 is offline   Reply With Quote
Old 08-11-2017, 10:35 AM   #12
z28lt1
Drives: 2014 ZL1
Yes, HUD shift lights will come on when:
1 - Driving such that you need a shift light (think it appears over a certain RPM)
and
2 - In HUD "Format 4" the one with the G-Meter as OneBatvATE noted
z28lt1 is offline   Reply With Quote
Old 08-11-2017, 04:03 PM   #13
San2cci
San2cci's Avatar
In the auto trans it is basically there to tell you when you're about to redline. If you don't shift before both sides meet the governor kicks on and it stops the car from going any faster until you shift up.
