08-17-2017, 08:59 PM | #1 |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Ratchet on stock SS seatbelts
I have seen people post about pulling the seat belt all the way out to get it to ratchet and then lock to keep you in the seat better. I can't seem to get the belt on my 2017 SS to do this. Is this only for the 1LE?
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
08-18-2017, 07:55 AM | #2 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
I haven't tried that on my 1ss but what i do is pull my shoulder out from the belt.
place the belt under my left arm and make sure its tight on my body. then pull the belt out as fast as you can. It should lock. then slide your shoulder back in and it should be tight.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
08-18-2017, 09:45 AM | #3 | |
Thanks
08-18-2017, 10:04 AM | #4 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
I have also heard that if you back your seat up a bit, pull the belt snug and then adjust your seat to tighten it up, it will stay locked until you unbuckle it. Haven't confirmed it though.
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
08-18-2017, 10:16 AM | #5 |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
I know my 16 SS doesn't have that feature. I had it on C6 Vette, so I thought newer Camaros would come with it, but sadly no. (it was one of the first thing I tried out when I got the car)
ZL1 has it. (I tried it in Becky's car)
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd 1100: 7/27/15 <SSWNNN> 3000: 9/04/15 <TPW:10/19/15> 3800: 10/19/15 <VIN: 117740> 6000: 12/16/15 |
08-18-2017, 10:57 AM | #6 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
My 1LE does have this feature, odd the normal SS wouldn't.
08-19-2017, 08:57 PM | #7 | |
Drives: '02 Z28 Join Date: Mar 2012
Good to know ........ thanks for confirming, guys. It may be trivial to some people, but it's obviously a good thing to be held snug in your seat when you're ripping around the track! Seems silly that GM wouldn't just include it in ALL of the 'Vettes and Camaros!?!
Current car:
2017 Cruze Hatchback - oh yeah! Previous cars: 2006 Z06 - LeMans Blue 2010 Corvette - LS3/MN6 - Black 2002 Camaro Z28 - LS1/T56 - Black www.time-attack.ca |
08-23-2017, 10:14 PM | #8 |
I wonder if you could fit the 1LE seat belt ratchet to an SS? I assume the mechanism is the only difference.
08-23-2017, 10:44 PM | #9 |
I suspect it's likely an internal function of the belt retractor, therefore, most likely requires a replacement of the whole belt/retractor mechanism from a 1LE / ZL1, but I could be wrong?!?
08-24-2017, 08:54 AM | #10 | |
Drives: 2016 1SS Join Date: Jan 2016
1. Move you seat backwards (and down) a few inches. 2. Start pulling the seat belt all the way. When you get almost to the end, pull it harder and you should hear a locking click. Release the belt quickly and it should lock on your body. 3. Move the seat forward and it should tighten the belt on your body. If it does not work: just move your seat backwards a few inches / pull it quickly to lock the belt, then while the belt is locked move your seat forward. Goodluck
1SS, Black, Black Wheels, A8, MRC, NPP
08-24-2017, 08:22 PM | #11 | |
