05-06-2010, 06:55 PM | #1 |
Drives: 2010 SS Join Date: Apr 2010
G8 vs Camaro suspension question
05-07-2010, 01:45 AM | #2 |
Drives: 5th Gen Rental Join Date: Aug 2007
The design is basically the same but here you go:
FRONTS front radius rod bushings larger in Camaro Balljoints larger in Camaro Strut and upper strut bushing totally different in the Camaro Sway bars totally different End links different Rear Trailing arm bushings have different size holes Camaro does not use a outer lower control arm bushing like the GXP Upper rear control arm bushing larger than G8 sway bars totally different. Lower control arms are beefier than G8 at the inner bushing the Camaro has a larger inner fender area and can accept a much larger tire than the G8. the Zeta 2 platform itself is more advanced than G8 Hope this helps mike dms |
05-07-2010, 10:53 AM | #3 |
Drives: 2010 1SS Join Date: Jan 2010
....and most importantly, the free height of the Camaro springs is approximately 1.5 inches shorter than the G8 springs.
05-07-2010, 11:03 AM | #4 |
cool
05-07-2010, 06:16 PM | #5 |
05-07-2010, 07:27 PM | #6 | |
The upper mounts and assemblies are significantly different as well Hope this helps mike dm,s |
05-08-2010, 09:00 AM | #7 |
05-08-2010, 11:25 AM | #8 |
05-11-2010, 04:28 AM | #9 |
Drives: G8 Maloo Join Date: Jun 2009
Can you find out how much it is?
05-11-2010, 04:30 AM | #10 |
I saw the thread title and was going to say 'wait for the Pedders gang to get here' and they already were here... They seem to know most about the Camaro suspension..
05-11-2010, 04:14 PM | #11 |
05-11-2010, 04:17 PM | #12 |
Its because I already make a shorter VE/G8 air bag strut here and want to see if it is short enough for the Camaro
05-11-2010, 04:35 PM | #13 | |
Now I will only be able to show you the differences with OE struts for now. Is that OK, or do you need XA strut comparisons? That will be harder to do thanks mike dms |
05-12-2010, 12:45 AM | #14 |
Just the difference in length from clevis to top of shock
Thanks |
Similar Threads | ||||
Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area | Info@PeddersUSA.com | USA - California | 6 | 04-30-2010 08:02 PM |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 05:33 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
