12-31-2013, 05:06 AM | #1 |
Drives: 2012 45th anniversary V8 LS3 Join Date: Jul 2013
Suspension upgrades - daily driver
Hi,
My car is daily driver only. But when I take cornes in higher speed, I feels like my rear end is moving and unstable. And I have some wheel hop under harder acceleration too. Lately I have been reading about suspension mods and I decided theese 2 ways. I like comfort ride of my car but on other side I want it to be more stable and solid when cornering. 1.) Bc racing coilovers plus bmr poly rear cradle bushing. 2.) Pfadt zl spec sway bars, pfadt rear trailing arms and tie rods, bmr poly rear cradle bushing. I have budget around 1500$. So what combination do you suggest for my need? Or do you suggest absolutely different combination? My car: 2012 ss, long tube headers, cai, tune. Thank you. |
12-31-2013, 07:00 AM | #2 |
Not sure on your two choices. I am doing the 1LE track pack. It will be installed on Jan 6th. I did put on the Hotchkis chassis brace and it helped with the wheel hop, the 1LE cradle bushings are allot better and stock and I should have all wheel hop gone after having both on.
I run street only but find every curvy road I can. |
12-31-2013, 07:15 AM | #3 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
The unstable feel you have is due to the rear IRS actually moving during cornering and hard acceleration. There are videos that Pedders did that shows the movement of the OE cradle bushings! The very first thing you should do is replace the rear cradle bushings with full urethane ones (or solids). Pedders and BMR have good full bushings and Pfadt has good solids. This is the foundation of the IRS! This will help eliminate the unstable feel that is called "rear end step out". Next, to help with wheel hop, replace the rear toe links, trailing arms, and outer bushings. You can do all of this within the $1500 budget. After that save up for a set of coilovers and lower it 1 1/4" (no more) and you'll have a killer set-up!
12-31-2013, 07:32 AM | #4 |
Drives: 2011 Camaro SS Join Date: Apr 2012
Could get bmr full bushing kit including cradle, trailing arms, toe rods, swaybars, lower control arms w poly bushings and lowering springs for about under 1500 while their sale is going on right now
12-31-2013, 10:00 AM | #5 |
Drives: Varies Join Date: Dec 2009
We just installed Pfadts Stage 1 ZL spec Drag Racing kit on a customers Whipple Supercharged Camaro and it completely changed the feel and ride of the vehicle!
This kit pretty much comes with everything you need... http://store.pfadtracing.com/camaro-...age-1-zl-spec/ It is a little bit more ( $149 ) than the $1500 you are trying to stay at but it's worth it! PM or Call me with any questions. Thanks JT |
12-31-2013, 10:14 AM | #6 |
Drives: 03 vette, 94 trans am, 04 gto Join Date: Jul 2012
option 1 would give you a great all around upgrade.
12-31-2013, 10:22 AM | #7 | |
Drives: 45th M6 Join Date: Aug 2011
12-31-2013, 10:23 AM | #8 |
I have 580-600rwhp depending on weather and dyno and have these with no wheel hop:
BMR cradle full bushings $249.95 BMR trailing arms $149.95 BMR trailing arm bushings $39.95 BMR toe rods $129.95 BMR upper control arm bushings $69.95
12-31-2013, 11:36 AM | #9 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Pfadt solid rear bushings $600
Pfadt sport sways & endlinks $600 Prothane radius rod inserts $30 Prothane steering rack bushing: $30
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
12-31-2013, 12:53 PM | #10 |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
12-31-2013, 02:38 PM | #11 |
FAVOR
Drives: Many Different Rides Join Date: Aug 2010
some Amsoil grease and a full suspension poly-bushing swap; makes the suspension respond instead of react (stock rubber).
Please be kind when you drive; thank you.
12-31-2013, 02:39 PM | #12 |
FAVOR
FTW.
12-31-2013, 02:44 PM | #13 |
Drives: 2017 Jaguar F Type R Tuned 498awhp Join Date: Apr 2013
how are the BC coil overs?
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
2017 Jaguar F Type R ''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller |
12-31-2013, 04:49 PM | #14 |
This kit comes with everything the OP pretty much wanted/needs.
Lowering Springs, front and rear sway bars, trailing arms etc... The " Drag Racing " wording is thrown around loosely and is just that, wording. He will be fine with this kit for a street driven daily. Did you read what the kit included or did you just see " Drag Racing " and immediately just questioned it? Thanks JT |
Thread Tools | |
