03-13-2017, 07:38 PM | #1 |
10,060 Miles as of 06/21
Drives: ‘10 2SS/RS, ‘17 Colo ZR2, ‘98 Tahoe Join Date: Apr 2010
Lucky 7
My 2010 SS turned seven today. So far the car has been trouble-free, although I'm thinking I should probably replace the OEM battery. I can't imagine that it has too much life left, even with only 9,350 miles (not a DD). The tires are also holding up well and still have good tread left on 'em but I'm not sure if they could have dry rot. Visually, they aren't exhibiting any sidewall cracks. Any thoughts other than I should drive the car more?
"The road goes on forever and the party never ends." - REK
"If we get a little crazy, blame it on the alcohol." PG "It's not the size of the dog in the fight, it's the size of the fight in the dog." MT "All bleeding stops eventually." Camaro EMT Patient: “This is my first time in an ambulance.” Me: “Mine too.” LOL |
03-13-2017, 08:18 PM | #2 |
Drives: 2014 2SS/RS Join Date: Dec 2014
Your Camaro must be in showroom condition at that mileage. Great choice in color!
Good thing you live down south, that seven year old battery would probably not make it through the snowstorm forecast for the Northeast today. My Son's 2009 Cooper has 24,000 miles on it, also with the OEM tires, some slight cracking in the sidewall's outer cover surface. Does not do much highway driving and lots of tread left.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
03-14-2017, 09:16 AM | #3 |
damn I have 7600 on my 2014 and I thought I had low mileage. :O Drive that sucker!!
03-14-2017, 09:33 AM | #4 |
Only way to know about the battery is to do a load test to measure its volts and the load % remaining of CCA (cold cranking amps) 765 CCA when new. Get a battery analyzer or take it a garage to be tested. At a minimum Volts should be 12.4 and CCA should be >60%. If they're at or very close to those nbrs when fully charged the battery is nearly at its end of life (as Dirty Harry said " are you feeling lucky today?") and should be replaced soon.
03-14-2017, 10:41 AM | #5 |
Started#gottalovethatblue
My Camaro is 8 in July and I still have the original battery in it. I did get it tested when I fired it up for the first time this year and it is showing signs of age. Next year I will likely be forced to replace it, but as of right now it still starts without any problems.
03-15-2017, 09:07 AM | #6 | |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
