04-14-2014, 07:57 PM | #1 |
One Slow Automatic
Drives: 2017 GS 2010 CAMARO SS Join Date: Mar 2010
What matters; HP or TQ?
I have seen guys that are blown/tt'd with high hp numbers and low tq numbers and vice versa on the different dynos...I want to know what matters; is it the tq or just hp?
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
04-14-2014, 08:08 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
They mean different things... Torque is the actual mechanical power that gets transferred to the wheels. Horsepower is a measure of torque with respect to engine speed, if I understand it. Torque always matters - it's the actual power. Horsepower is more for talking... short and vague explanation.
04-14-2014, 08:13 PM | #3 |
Drives: black on black 2SS/RS Join Date: Feb 2010
Trq is what put the car in motion!!!!
04-14-2014, 08:39 PM | #4 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
I think both. Torque get u going, horsepower keeps u going.
04-14-2014, 08:39 PM | #5 |
Torque. Cannot have HP without torque. You want to build as much torque as you can and carry it as high as you can in rpm. HP is figured off of torque. You measure torque and then figure HP.
04-14-2014, 09:10 PM | #6 |
One Slow Automatic
Ok this makes alot of sense...I was comparing the last dyno sheet with the new one which triggered my question...
04-14-2014, 09:20 PM | #7 | |
Boosted Moderator
http://www.hotrod.com/techarticles/h...sepower_guide/
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
04-14-2014, 09:40 PM | #8 | |
One Slow Automatic
04-14-2014, 09:52 PM | #9 |
Banned
Drives: Camaro Join Date: Mar 2013
Torque gets you going quick, HP gets you going faster.
04-14-2014, 11:35 PM | #10 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-15-2014, 12:48 AM | #11 |
Correct which is why dyno graphs cross at 5252rpm.because that's the constant in the equation.
04-15-2014, 06:46 AM | #12 | |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Read it, understand it and don't let a bunch of old sayings trap you in a vortex of misunderstanding.
Rocket engines can produce a lot of horse power with no torque.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread Last edited by GretchenGotGrowl; 04-15-2014 at 07:45 AM. |
04-15-2014, 04:16 PM | #13 |
Drives: Silver 2SS, 68 Firebird 400,70 vett Join Date: Jul 2009
Carrol Shelby once said torque wins races horsepower sells cars. When you have a heavy car to get moving some good torque would be nice.
04-15-2014, 05:12 PM | #14 |
They produce thrust though. Similar concept to torque - in that it's the force that effectively moves the object.
