12-10-2018, 01:15 PM | #1 |
run ur car not ur mouth
Drives: 2013 1LE Join Date: Jul 2013
I've ruined my 1LE......sorta kinda
Truth be told at the end of the day I would've been better off getting an SS. I never had any real intentions of doing any road courses. I've been a 1/4 mile guy my whole life. So did I waste money buying the 1LE instead of an SS considering my intentions with this car and the way I've built this car? The way I see it the only positive is the 3:91 gears.
Sent from my SM-G950U using Tapatalk
TSP headers, cat delete, x-pipe, atak, RPM custom cam and tune, Phfadt 1.25 springs, 15" Carlyle conversion, Nitrous Outlet, Procharger F1A-94, Meth inj
12-10-2018, 01:18 PM | #2 |
Instagram: Sangstah
Probably but you are right about the 3.91 gears being a plus, either way you built a badass car!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
12-10-2018, 02:39 PM | #3 |
Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Actually, you're wrong about the 3.91s being a plus. Because of the different gearing in the 1LE transmission, the 3.91 isn't any faster than rear gear in a standard manual SS.
Scroll down to the "Transmission Section" in the following URL: https://media.gm.com/media/us/en/che...2014.tab1.html
My thoughts on some things:
12-10-2018, 02:46 PM | #4 |
Calculating it out:
First gear is a 10.38 on the SS and a 10.40 on the 1LE. Tie Second gear is a 7.14 on the SS and a 6.96 on the 1LE. Advantage SS Third gear is a 4.93 on the SS and a 5.1 on the 1LE. Advantage 1LE Fourth gear is a 3.45 on the SS and a 3.91 on the 1LE. Advantag 1LE Fifth gear is a 2.90 on the SS and a 2.89 on the 1LE. Tie Sixth gear is a 1.97 on the SS and a 1.96 on the 1LE. Tie And none of the gears are a major advantage either way. The 3.91 was added to the 1LE to keep the acceleration similar to an SS given the ratio changes.d
12-10-2018, 05:03 PM | #5 |
Tri-County Camaro SWFL
Yeah u wasted money on it but who really cares. Seen your car in RPMs back storage room for a long time. Glad you finally got it back and can enjoy the new hp
12-10-2018, 05:15 PM | #6 |
Drives: 2011 2SS Join Date: Mar 2015
Well I mean you did have the zl1 pump and beefier axles but you may have already replaced those for stronger parts
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
12-10-2018, 08:32 PM | #7 | |
Drives: Miss Con Ception Join Date: Aug 2016
1st 11.766 Advantage 13% 2nd 8.092 Advantage 16% 3rd 5.590 Advantage 10% 4th 3.909 Even 5th 3.284 Advantage 13% 6th 2.228 Advantage 14% On the strip an SS with the 3.45 will hit 113MPH in 3rd@6600, eliminating a shift to 4th on stock power. I'm pretty sure that crossed the engineer's mind when deciding on the overall ratios. The 1LE will reach 106MPH@6600 in 3rd. 109 with the slightly taller SS tires.
2011 1SS/RS LS3 CGM
12-10-2018, 09:27 PM | #8 |
Yeah they let me store my car there when I was building my new house. Awesome shop with great guys.
12-10-2018, 09:31 PM | #9 | |
12-10-2018, 10:24 PM | #10 |
Yeah that 1LE is shot now ! Looks like you can give it to me .. hahaha.
Bad ass car brother and looks great.
Car mods: never enough!
12-11-2018, 04:09 AM | #11 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Sweet looking ride
What does she run?
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
12-11-2018, 07:18 AM | #12 | |
I want them to do heads and cam on my car but I don't think I'm going to be driving it 20+ hours when I go up there in April. 1LE or not, your car and build is awesome.
12-11-2018, 07:25 PM | #13 | |
12-11-2018, 07:25 PM | #14 |
LOL, thanks man.
