Old 07-11-2014, 02:14 PM   #1
1LESSPROBLEM
Drives: blown
2013 converter vs 2014 covnerter (6L80)
I see that the PN's for the 2010-2013 flexplate is different from the 2014 flexplate in the SS camaro. I want to know if there are any differences in the spacing on the converters between the 13 and 14 models. If any of the converter/trans vendors could chime in I would greatly appreciate it.
Thanks in advance.
VF Commodore
LSA
Heads
Cam
Weld
1LESSPROBLEM is offline   Reply With Quote
Old 07-12-2014, 01:45 PM   #2
Circle-D_Brian
Circle-D_Brian's Avatar
Drives: 00 Trans Am
The converters are the same. You still need an 1/8 inch of converter clearance if that's what you mean by spacing.
-Brian
Circle-D_Brian is offline   Reply With Quote
Old 07-14-2014, 08:17 AM   #3
1LESSPROBLEM
Drives: blown
Ok, reason I ask is because Im putting a converter in a 2014 SS Sedan and I just wanted to make sure the clearances were the same as the camaro's. the different PN's on the flexplate threw me off so just wanted to double check.
VF Commodore
LSA
Heads
Cam
Weld
