Old 08-09-2014, 02:04 AM   #1
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
clutch/brake fluid question
I have a 1LE that makes 490 to the tires, anyways, took the car out tonight and like someone flipped a switch it developed a hard clutch pedal, so I checked the brake fluid and is very dark, the car only has 7700 miles but does kill a mustang or two on the weekends, no sidestepping the clutch, I'm over all that, just roll launches for me.....so any info on service or fluid requirements would be very helpful, thanks.
1fast1le is offline   Reply With Quote
Old 08-09-2014, 08:07 AM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
You need to change the fluid at the least. There are some threads on it. The clutch dust has contaminated the fluid. This is a common issue here. You can separate the fluids with a separate reservoir for the clutch and that will make fluid changes easier and prevent damage to the brake system. Hope that is all you need.
-Mark.
Old 08-09-2014, 11:55 AM   #3
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
thought that might be the solution, thanks for the reply.
Old 08-09-2014, 01:01 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
For what it's worth, try to use DOT 4 brake fluid too.
DSX_Camaro is offline   Reply With Quote
Old 08-09-2014, 05:03 PM   #5
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
Bad news, got the dot 4 put in, drove it to the wash and lost the clutch(throughout bearing) fluid from the bellhousing and pedal stuck on the floor, so.. does anyone have clutch and bearing insite? If I pull the tranny no sence in not putting a clutch also.
Old 08-09-2014, 05:41 PM   #6
Synner
Drives: cars
I would swap out the master and slave to ensure you get the problem. The throwout bearing wouldn't vomit fluid but the slave cylinder would. If you plan on dropping the trans then put in a tick clutch line and speed bleeder line.
Motul RBF600 is great stuff for a fluid choice.
As far as clutch goes I'm considering the Centerforce DYAD clutch as the #1 choice. Although the Mcleod and Street Slayer options are right there too.
Old 08-09-2014, 05:54 PM   #7
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
thanks for the info, back to the garage...
Old 08-09-2014, 07:18 PM   #8
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Originally Posted by Synner View Post
IIf you plan on dropping the trans then put in a tick clutch line and speed bleeder line.
+1 on the Tick lines. Did both myself. Makes bleeding the clutch so much easier.
bannonm is offline   Reply With Quote
Old 08-09-2014, 07:42 PM   #9
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
The clutch bleeder screw is inside the bell housing, could be it backed itself out and unloaded your clutch fluid?? Did the fluid level in your reservoir go down?
tw78911sc is offline   Reply With Quote
Old 08-09-2014, 07:52 PM   #10
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
Do the Tick lines come with their own reservoir?
Old 08-09-2014, 07:55 PM   #11
1fast1le
1LE.SS
1fast1le's Avatar
Drives: '13 2ss/1LE
Was having hard pedal issues nite before and super dark fluid, was just hoping for lucky brake changing fluid, now i know fluid needs to be changed every so often.
Old 08-09-2014, 08:16 PM   #12
Synner
Drives: cars
No.
Old 08-09-2014, 08:18 PM   #13
tw78911sc
tw78911sc's Avatar
No it does not, I used a JDP reservoir kit and have the Tick remote bleeder line. It works great, 6-8 pedal pumps and the whole clutch is flushed w/o getting under the car, remote line is close to the reservoir so you can keep an eye on the fluid getting low.
Old 08-13-2014, 10:22 AM   #14
TX_ED_SS
TX_ED_SS's Avatar
Drives: 2010 2SS/RS Inferno Orange
I did the separate reservoir mod about six months ago and I'm really pleased with it. Flushed the brake system at that time and the fluid is still clear. The clutch fluid is easily changed when it gets dark and the pedal feel has been great.
U.S. Army Retired
TX_ED_SS is offline   Reply With Quote
