01-08-2022, 03:13 PM | #1 |
Space Coast Camaros
Drives: 2012 Camaro Vert Join Date: Sep 2011
Diff Bushings - BMR Black Street 6+ years old and cracking
Upgrading my gears to 3.91 and TrueTrac and noticed my BMR bushings are all cracked. Is this normal for only 6-7 years? I did have Twin Turbo's for most of that time :-) Are there better ones to use? maybe other than BMR? or maybe these BMR - Poly/delrin Combo would be better? |
01-08-2022, 03:25 PM | #2 |
Space Coast Camaros
Maybe these would be better? But i hear they have Noise issues
HENDRIX OFFSET REAR DIFFERENTIAL BUSHINGS https://www.phastekperformance.com/H...-hen-01-po.htm Last edited by KalCorp; 01-08-2022 at 06:48 PM. |
01-09-2022, 08:25 AM | #3 |
Well THAT sucks!! Never seen that before...
01-09-2022, 09:14 AM | #4 |
Drives: 2012 Camaro SS Join Date: Dec 2019
How much hp were you pushing? Maybe there was a lot of flex there.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
01-09-2022, 05:04 PM | #5 | |
01-09-2022, 05:11 PM | #6 |
Yea, I'm curious on that too!! All the time I've seen your car, you have never even told me how much you have. Looks good though!! lol..
01-09-2022, 08:33 PM | #7 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I thought the Solid Cradle bushings don't transfer noise, I always heard the Diff Bushings do.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
01-10-2022, 07:34 AM | #8 |
Probably both do somewhat. But in my install I did pick up some because the mounting points now are metal to metal, no cushion between them, and no flex.The rest are the stock rubber bushings but them not being solid, or delrin/poly, it's not too bad. Tolerable. Just how mine is. I did notice a difference after the install though.
01-10-2022, 07:43 AM | #9 |
Gotcha I am not looking to pick up to much noise. As I do want this to be a car I can take on a trip and not be annoyed as well.
01-10-2022, 08:03 AM | #10 |
Yes sir, I hear ya there. Like I said, it is not that bad at all. Now if I had done the diff bushings and made THAT area more solid, along with the cradle bushings it would probably be worse. That's why I only wanted to do the cradle ones cause I do cruise a lot for extended times. So leaving the rubber ones in the diff leaves me some cushion. Plus these cradle bushings I did on the reccomendation from JDP Motorsports to get rid of my wheel hop I was having, as they have cars they track, and it worked!! So I'm good to go. Thanks JDP..
01-10-2022, 10:05 AM | #11 |
Space Coast Camaros
I was only looking at the OFFSET REAR DIFFERENTIAL BUSHINGS because I got the AirRide and I have it lowered for normal driving.
I am going to try to talk to BMR today and maybe order some one bushings. |
01-11-2022, 08:46 AM | #12 |
That's what I would do D, call BMR and let them know what's up with those bushings, who knows, they might just replace them for ya with some better ones. I have seen a lot of folks here do the offset bushings for the diff to correct the pinion angle on lowered cars because lowering they say puts the axle shafts at a weird angle along with the pinion. Good luck!!
01-11-2022, 10:24 AM | #13 |
I spoke with the Owner of Hendrix today and he seems like a honest guy, After speaking with him i am leaning towards his Offset Poly Bushings and His Solid Cradle. The Poly are not on his site as he like myself are not good with this computer stuff.
01-11-2022, 02:13 PM | #14 |
Space Coast Camaros
Talked to BMR and they said i was over the Street version of the bushings.
They recommended the BMR - Poly/delrin Combo ones. Going to order them and try them out. https://www.bmrsuspension.com/index....productid=1273 |
