08-25-2013, 02:45 PM | #1 |
Help rear tire wont relearn
I installed new tires on my car and now the light blinks and when i try to relearn everyone learns but when i get to the last one the one on the driver side rear it wont learn like the rest. if any of you had this problem what did y'all do to fix it?
08-25-2013, 04:28 PM | #2 |
Bet it's bad. The good ones only last 5-7 years and have had few that are 3 years old go bad right after a tire change. This is all cars not just GM. At lest the Camaro does not use the $50 each like my 08 G6.
08-25-2013, 04:29 PM | #3 |
Drives: 2015 Cummins Join Date: Jul 2013
I hate mentally challenged rear tires.
08-25-2013, 04:48 PM | #4 |
Drives: Inferno Orange 2SS RS Convertible Join Date: Aug 2011
My dealer does it for nothing with there relearn tool. Ask your dealer if they can do it for you.
Likes to Cruise!!!!
08-25-2013, 11:24 PM | #5 | |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
You have the wrong last tire. You are suppose to start with the front passenger, then rear passenger, then rear driver and finish with the front driver's tire.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
08-25-2013, 11:55 PM | #6 |
Drives: 2011 2ss/rs Join Date: Nov 2011
Um sorry no. You start at drivers front passenger front passenger rear driver rear. I'm on my third set of rims, have done it many many times.
08-26-2013, 01:08 AM | #7 |
yea what he said. lol im doing it right the dealer did it to same way, but they trying to charge me to see whats going on
