08-03-2014, 08:31 AM | #1 |
Drives: black2ss Join Date: Jul 2010
with 391 gears
with 391 gears what gear are u bolt on guys going through the 1/4 mile in this means stock 20in tires and stock converter on a auto l99
08-03-2014, 10:16 AM | #2 |
Drives: Camaro SS/RS inferno red interior Join Date: Mar 2012
Man I wish I could answer this question. Even with all my mods I still haven't gone to the track yet
SoFlo Muscle Car Group
Miami/Broward |
08-03-2014, 06:49 PM | #3 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
I also have a 3200 stall, I'm going thru in 4th gear.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
08-04-2014, 06:08 AM | #4 |
Mark Stanford
Drives: Black 2010 SS LS3 Join Date: Aug 2010
4th. M6 car with 3.91 and 27" diameter tires.
Mark Stanford
2010 M6 Midwestracing on FB CAI, Kooks 1 7/8" 3", LG G6X3, Remote tune by Ted Jannetty JRE God of Tuning, ID 8500 injectors, ZL1 Fuel system, BMR, Yellaterra, Lunati Valve train, Street Slayer Carbon Twin. Numbers pending Dyno test. |
08-04-2014, 08:20 AM | #5 |
Writer
Though Mark's car has a cam I'd think he's shifting a lot higher than an A6 would with stock internals.
PROJECT HEAVY CHEVY
08-04-2014, 03:55 PM | #6 |
M6 cammed 3.91's on stock 20's is 4th gear about 5700 crossing the line.
08-04-2014, 09:14 PM | #7 |
Drives: 2011camaro SS Join Date: Nov 2012
John what rpm are you shifting at and what rpm are you crossing at in 4th
To my knowledge ProStockJohn is the only L99 with a stock cam and 3.91's that has proven that this will work. Can anyone else with same mods confirm? |
08-04-2014, 09:52 PM | #8 |
Drives: none Join Date: Aug 2011
Some bad math tells me that 6200rpm should be good to 114-115mph with a 3.91, 1.15, and 27.8 inch tire.
In an A6 that would have to happen with a locked converter. You can probably add another 300 unlocked. Got a datalog of a pass from yesterday John? |
08-04-2014, 10:35 PM | #9 |
Writer
I could send over a log tomorrow, but I was trying all sorts of shift points so some of them ended up being too high. But the time I went out before I had no problems.
PROJECT HEAVY CHEVY
08-05-2014, 12:11 AM | #10 |
"Cam Only"
If I have a 2013 LS3 SS,
and if I put in 3.91's in the rear, and I have a decently sized cam, and I shift at 7000-7100, what will my RPM's be approximately when I cross in, I'm assuming, 4th..? I'm looking to do 3.91's soon, will it be much of an advantage over the stock 3.45s for 1/4m?
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) Last edited by Jeff_SS; 08-05-2014 at 12:26 AM. |
08-07-2014, 04:46 PM | #11 | |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
08-07-2014, 04:47 PM | #12 |
Writer
FWIW my shift points were all 6100 and over and I went thru the traps just fine in my car.
PROJECT HEAVY CHEVY
08-08-2014, 01:08 AM | #13 | |
"Cam Only"
Gonna do the 3.91's in the next month or two.
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
08-09-2014, 07:24 PM | #14 |
You will love them!!! With a larger cam like you have your car will fly!
Thread Tools | |
