10-29-2023, 05:07 PM | #1 |
Drives: 2017 ZL1 Camaro A10 Join Date: Sep 2017
Battery Charging Location
Question, will be away for 7 weeks and purchased a Battery Tender and wondering if it matters where I connect, battery in trunk, which is a little hard to get to, or OK to connect under hood at fuse block front left? Thanks.
10-29-2023, 05:29 PM | #2 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
I always connect the tender under the hood.
10-29-2023, 06:14 PM | #3 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Yup, you can use the underhood +/- contacts, they were added specifically for this reason.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
10-29-2023, 07:00 PM | #4 |
Agreed. I use the under hood terminals. Works great!
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
10-29-2023, 07:01 PM | #5 |
Great, thanks guys
10-29-2023, 08:17 PM | #6 |
NYTMARE23
Drives: Black 2023 Chevrolet ZL1 A10 Join Date: Oct 2022
I go direct to the battery for the winter months. It's not that hard to connect to...
2023 A10 ZL1 "NYTMARE"
10-29-2023, 09:31 PM | #7 | |
A few people built a "charging port" into the floor or the rear bumper/diffuser using something like this, now that is an interesting solution that's indeed easy to use
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 10-30-2023 at 07:19 AM. |
10-29-2023, 11:50 PM | #8 | |
NYTMARE23
10-29-2023, 11:57 PM | #9 |
Drives: '24 ZL1 A10, '70 Olds 442 W-30 Join Date: Sep 2023
The fuse block under the hood is a good way to go. Your trunk will remain closed, so the trunk light won't be on continuously.
10-30-2023, 04:45 AM | #10 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Owners Manual says you can jump under the hood, so………….
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
10-30-2023, 06:14 AM | #11 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I just have a permanent plug and play tether like I have on my bikes, but I have yearly winter storage
10-30-2023, 06:27 AM | #12 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
The battery minder manual says to hook it up directly to the battery. The Camaro owners manual says to jump the car from the terminals under the hood, but jumping and charging are two different operations. In the case of jumping, you want the voltage to be as close to the starter as is practical. For charging you want the voltage to be as close to the battery as practical. There will be a voltage drop while traveling through the wiring involved. I’m sure it’s not enough to keep the battery minder from working, but it’s not the optimal condition.
10-30-2023, 07:17 AM | #13 | |
NYTMARE23
10-30-2023, 07:30 AM | #14 | ||
By the way, I updated my post that I forgot to press submit on last night with a link. Also, here is a page with several ideas: https://www.camaro6.com/forums/showt...=540177&page=2 Quote:
