11-08-2012, 02:45 PM | #1 |
Drives: 1996 Camaro RS convertible Join Date: May 2009
My 96 RS build thread!
well since I've never posted it on here before, here goes.
02/2005 1996 RS 60k miles new front nose emblem bad choice with billet grille another bad choice on flowmasters and rear euro markers black outs inatke and first STB no pics 32/21 1LE sway bars with poly bushings and endlinks
11-08-2012, 02:45 PM | #2 |
interior change neutral to ebony and wrapped dash parts.
11-08-2012, 02:46 PM | #3 |
and RED LEDs
new wheels and tires berger mod eurolights with HIDs 6k
11-08-2012, 02:46 PM | #4 |
Borla goes in, with corsa clones
dyed top 3 point Kenny Brown STB other parts with no pics new J&M Panhard J&M LCA's 3 piece poly-ball bushing UMI SFC's poly bump stops new hood finally a tonneau cover
11-08-2012, 02:47 PM | #5 |
Cam and valve train upgrade time
11-08-2012, 02:48 PM | #6 |
Well after wasting around 3hrs or so, trying to get a lifter out of the oil pan, that I forgot to take out. The new GT2 cam and JP performance timing chain set are finally in. Maybe next weekend we can start this baby up........=:-)
finished the intakes
11-08-2012, 02:48 PM | #7 |
and where its at now
1996 Camaro RS Convertible Exterior Color: Arctic White Interior Color: Netuarl Leather Engine: 3800 Series II V6 Transmission: Automatic 4L60E Factory Options: Fully Loaded Exterior modifications: -Harwood 2.5" cowl hood -Black carbon fiber nose emblem -Berger mod with white camaro emblem inserts -Red Calipers Interior Modifications: -Ebony leather interoir swap -Red LEDs in dash -Custom vinyl wrapped dash and trim Performance: -Full cold air intake by chromeintake's -GT2 Cam -LS6 #90 yellow springs -Comp pushrods 7.05 5/16 .080" thickness -Viton Valve Seals -INTENSE Re-usable Rocker Arm Bolts -JP Performance Single Timing Chain -Manley Performance Valvespring Retainers -Comp OE lifters -Pacesetter Headers -Borla PRO XS -4" Corsa Clones -NGK TR55 spark plugs -MSD 8.5MM Super Conductor Ignition Wires #32799 -180 Thermostat Suspension: -UMI red SFC's (weld-in's) -Kenny Brown 3 point STB -J&M LCA's 3 Piece Poly Ball Bushings (red) -J&M Panhard Rod (red) -32mm 1LE Front Sway Bar (black) -32mm Prothane bushings (red) -Front Energy Suspension End links set (black) -21mm 1LE rear sway bar (red) -21mm Prothane bushings/end links set (red) -red ploy bumpstops Wheels/Tires -17' SS 10 spoke wheels -275/40ZR17 Riken Raptors Brakes: -Slotted and cross drilled rotors Electronics: -SLP Fan Control Switch -Pioneer DEH-P7700MP Head Unit -Blaupunkt GTc652 6-1/2" Component System -Blaupunkt GTx662 6-3/4" 2-way Speakers
11-08-2012, 02:49 PM | #8 |
drive down to PCB FL
and tuning with Scott drive back home
11-08-2012, 02:50 PM | #9 |
Drives: 2002 Camaro SS; 2001 Silverado Join Date: Aug 2008
Looks good. Nice to see somebody putting a lot of TLC into a V-6 model.
11-08-2012, 02:52 PM | #10 | |
fall in GA
11-08-2012, 03:16 PM | #11 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Nice thread. Great to see all this work and a well-maintained RS!
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
11-08-2012, 03:31 PM | #12 |
Drives: nothing Join Date: Nov 2010
Great looking 4th gen'.
11-08-2012, 04:30 PM | #13 |
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
Looks clean man, I like what you've done with. Got any exhaust clips?
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension 2004 GSXR 1k, Matt Mladin Edition |
11-08-2012, 06:47 PM | #14 |
Drives: '11 VR 2LT HHr Join Date: May 2011
Nice changes you have made to your RS !!
Very Nice Vert ! ! ! !! ! !
2011 Hhr
Formerly known as Silver85IrocZ !! |
