06-08-2010, 01:24 PM | #1 |
Drives: '10 LT1 CGM "Sweet Emotion" Join Date: Mar 2010
Adding ABL what else do I need?
I am adding ABL to my LT1 doors. I have the door panel inserts, two of the blue led lights......what I am missing is the what carries the light down the length of the door. In another thread I was told it was number 17 in the below diagram the "lens back". Is this correct? Is this all I will need to complete my project? Anything I am missing? Any help /suggestions greatly appreciated.
use this link if photo didnt upload correctly http://www.gmpartshouseusa.com/partl...layCatalogid=0 Txrhino Kevin '10 LT1 CGM "Sweet Emotions" Pics Coming Soon |
06-08-2010, 01:31 PM | #2 |
You will probably have to tap into the light in your door switch to power the LEDs.
I haven't taken the door panels out lately, but that is probably the yellow wire as that is what it is for the traction control switch, and sunroof switch. If you do it, you will be the first known 1LT that did the ambient lighting. Suggestion, see if you can find some door panels at a junk yard. www.car-part.com is a good starting point. Maybe you can get the tube from there. |
06-08-2010, 01:34 PM | #3 |
06-08-2010, 01:37 PM | #4 |
I purchased the door panels from a camaro5 member he kept the ambiant lighting part. I just want to make double sure the part number 17 is all I will need to complete my mission. Not that finding this piece as a stand alone piece will be easy. http://www.gmpartshouseusa.com/partl...layCatalogid=0
Just don't want any suprises when I pull my panels. Thanks, Kevin |
06-08-2010, 01:54 PM | #5 |
www.Camaro5store.com
In order to do the lighting in the doors, you need light pipes, which I have heard are discontinued. I know for fact there are other forms of tubes w/ already attached LED's. But, yes. To answer your question, all you need is #17. I think it was "digi-key" that carried them. Look at their site and you are going to find some awesome stuff, parts, and alternatives if they don't carry the light pipe anymore.
Again, all you need are the GM lights (x2 blue), two light pipes from digi key, and a way to tap into the wires. I know shutduck has all the wire connections down. He's Mr. Electrical when it comes to this stuff. Have fun looking and go to digikey for SURE! |
06-08-2010, 01:57 PM | #6 |
Drives: 2010 supercharged LS3 Join Date: Jan 2010
Skuttduck - I've looked around the DIY's and seen you in there alot. Is there a DIY for putting ABL in a 1SS (without any of the power hookups or anything) if there is I can't seem to find it
06-08-2010, 02:00 PM | #7 |
06-08-2010, 02:02 PM | #8 | |
All you really need is a 5MM light pipe of some sort. All it is, is a clear rod 5mm in diameter with a straight line that is white on the back. You could probably use an acrylic curtain rod, and paint the back of it white to do the same thing. |
06-08-2010, 02:08 PM | #9 |
I have never seen inside a door equipped with ABL. I am also doing my dash panels and have the digi-key tyco light pipe for that install. So part number 17 is a light pipe? I guess the name "lens back" just throws me off. I have been told it has to be purchased as a complete set with the panels from GM but hopefully I can track some down from GM.
My question "lens back" = light pipe? Thanks, Kevin |
06-08-2010, 02:19 PM | #10 | |
Yes that is correct. There is a special bend at the end of the GM one because of the curve of the door. Other than that, it is a 5mm clear acrylic tube with a piece of white plastic to help reflect the light. There was a thread where someone had made a guide on how to extend the ambient light all the way to the dash. If I could find that, this would help. |
06-08-2010, 02:30 PM | #11 |
So many thanks,,,,I just really want to be sure before I start taking things apart.
Kevin I love this site found out what I needed to know in less then thirty minutes!!! |
06-08-2010, 04:16 PM | #12 |
Drives: 2010 Camaro SS/RS Join Date: Apr 2009
The power connector should be in the door. Even if this is a LT, the wiring should be there, 'cause they're all wired the same.
I may suggest a second light on each door, this way the light will be even across the panel. The factory abl has a "dummy light" to hold the forward end of the light pipe. Put this second light in that place. You'll like what you see.
Jayhawk500
2010 2SS/RS, Six speed, Rally Yellow w/ Black Painted Stripes, Boston Acoustic Stereo, Polished 20" wheels, Solo Mach X Catback Exhaust, Solo HF Cats, Halltech CAI, Full Dash & Door ABL, ABL Lit Homelink Buttons, HUD Installed, Ride Tunes, Full Electric Passenger Seat, Fbodfather signed, VIN # 4492, PAID OFF!!! 2010 Yellow 2SS/RS with black painted Stripes...$37,000.00; Ride Tones sound system and remote...$ 40.00; Seeing the kids faces (Young and Old) light up and almost wet their pants....Priceless!!! |
06-08-2010, 10:53 PM | #13 |
Search for ABL in the title of the DIY section. There's a BUNCH there. I have not wired it, but taken it all apart, extended the ABL on the doors, installed ABL on teh dash...tons of stuff (even did it in el wire too). SO...any questions, pm me. Only thing I can't do is help you on wiring (shuttduck has that one down) |
06-13-2010, 08:34 AM | #14 |
Drives: Black Join Date: Jan 2010
Tag, there are a lot of posts on ABL, io your opinion which is the best method for the dash, taking in consideration, matching light consistency and color? I have syn green.
The light tape sounds cool, but is it too bright? Is oem light tube or tape? |
Similar Threads | ||||
Ambient Lighting (ABL) development summary | McGruff | 5th Gen Camaro SS LS LT General Discussions | 77 | 03-27-2012 12:27 AM |
DIY: ABL Color Change | Tecca | Camaro DIY & HOW-TO instructions & discussions | 20 | 05-18-2010 06:50 PM |
ABL lighting and Footwell Light Install? | JProberts | USA - Mid-Atlantic | 3 | 02-25-2010 10:17 PM |
ABL 1LT or 1SS | bkkendrick | Cosmetics and Lighting Modification Discussions | 1 | 10-28-2009 12:11 AM |
OMG ABL!! | AVNMechanic | Camaro Photos | Spyshots | Video | Media Gallery | 13 | 04-20-2009 07:16 PM |
