07-01-2013, 02:27 PM | #1 |
Gas Performance of AC vs Drag
I brought up in one of the gas mpg threads "Does running the AC affect my mpg?" and I decided to do some research. Of course the answer is yes, but what about windows down vs AC?
In today's world, the average (modern) car is fairly aerodynamic and getting better at gas usage. When it comes to deciding to roll the windows down or run the AC, it seems physics solves the issue (sort of). The general rule I found was that 52mph is the average speed where having the windows down will lower gas efficiency due to drag. Anything under 52mph with windows down allowed the car to utilize the gas more efficiently. Now that was a GENERAL AVERAGE amongst standard cars. I know that our cars are probably more aerodynamic than most, but has anyone really had firsthand experience with this in the community? I haven't had the luxury of a LONG ride yet, but I would love to see REAL LIFE inputs on performance difference. Other interesting questions: How does a convertible affect the aerodynamics of the car/gas efficiency (down and up)? How does the convertible 2nd set of back windows (top up) affect the aerodynamics of the car/gas efficiency? TLDR: Ride with your windows up and AC off and your car will be at max performance
2018 2SS hot wheels convertible
07-01-2013, 02:42 PM | #2 |
The gritos pollo!!!
interesting. seems at 70+ i get a lot of air turbulence in side the car with them down. now you have me wondering.
______
If you don't stop how can they give you a ticket?-The Big Tuna___ '12 1Ls Camaro; Slp loud mouth I|maganflow x-pipe|Injen long ram intake|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can| '13 Avenger R/T '77 T/A 6.6;, draining my wallet. |
07-01-2013, 02:56 PM | #3 |
you will definately get better gas mileage with windows up and AC on over having windows down.
2012 2LT/RS AGM- Injen CAI- MRT v2.0- Elite catch can- VMax PTB- ACS T5 splitter,rockers, rear panels and T2/s ports- Strut brace- Oracle side markers- JDP DRL Harness and ACS Eagle T2 leds-5% tint-Decepticon theme |
07-01-2013, 03:57 PM | #4 |
Drives: Camaro 1ls Join Date: Apr 2013
Just drove mine from delaware to florida. 1600 miles on it to start, 2500 now. 1ls, ran as high as 30.1 ac off some traffic caused me to end with 29. When it got to hot went to ac and ran 28-28.5mpg. Range of speed was 60-77 ran 5 to 7 mph over speed limit all the way.
07-01-2013, 04:12 PM | #5 | |
07-01-2013, 04:20 PM | #6 |
knows 2 facts about ducks
Myth busters did an episode on this. I'm sure it's on the YouTube somewhere.
And windows down will increase the drag coefficient as air is being sucked into the cabin. |
07-01-2013, 04:23 PM | #7 |
Drives: 2011 Camaro Synergy II Join Date: May 2013
This will be interesting...
Our cars are narrower across the rear of the window opening, than across the front. That would lead me to believe that the windows down would not make much of a difference than up. On the Camaro anyway. Hmm... Lee |
07-01-2013, 04:30 PM | #8 |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Ummm... Isn't this just common knowledge?
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
07-01-2013, 04:44 PM | #9 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
I thought modern AC and ventilation systems work in such a way that the compressor cycles on and off whether we are using AC or not. Even in the winter while we use the heat. Don't they cycle on/ off year around to keep them lubricated?
In which case, the drag on the engine would be the same either way.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
07-01-2013, 05:18 PM | #10 | |
Drives: 2012 camaro Join Date: Feb 2012
yes, but that was only at speeds over 50. the first time they did it they kept the speed low, like 25 or something, so the tires wouldn't wear as bad. and that result showed no change in MPG. the second time they did it (because a lot of people wrote in making note of the speed) they ratcheted the speed up and it did in fact show a decrease in MPG with the windows down. |
07-01-2013, 05:54 PM | #11 |
Back in the day when AC compressors were piston type you could really tell the difference in drag and mileage. Turn one of those baby's on and the car slowed down. With the new style rotary AC compressors they have much less drag. No mater how much it costs, I am keeping my AC on while I drive the car. I want to be comfortable. There's more to life than gas mileage.
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
07-01-2013, 06:02 PM | #12 |
The gritos pollo!!!
almost fell over when i saw the stig has "fireproof moderator"
______
07-02-2013, 07:40 AM | #13 |
So I guess the only people who have knowledge/information about the aerodynamics of the car is GM. I guess we just have to trust that they are thinking of windows down drag.
I am still curious how much drag a convertible produces with the top up and down.
07-02-2013, 08:45 AM | #14 | |
Drives: 2013 Blue Ray 1LS M6 Join Date: Apr 2013
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller Aesthetic Mods Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items |
