08-26-2014, 02:02 PM | #1 |
Drives: Camaro Join Date: Apr 2009
Texas Speed ALUMINUM 9.1" & 9.4" Pullies Finally In Stock!
Guys I'm proud to say the all aluminum version of the TSP ZL1/CTSv pullies are now in stock! At under 10 lbs these pullies not only add tons of power, they also save tons of weight!!
http://www.texas-speed.com/p-4303-te...nal-boost.aspx |
08-27-2014, 09:17 AM | #2 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Is this a 18% pulley?
Swift....Silent....Deadly
08-27-2014, 11:12 AM | #3 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
How do the weight of these compare to other pulleys that have been available for a while? I'm concerned about the lighter weight causing harmonics that may lead to premature bearing wear.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
08-27-2014, 11:17 AM | #4 |
Going for Plaid
Do you need the LPE bracket with both sizes of pulley?
08-27-2014, 08:39 PM | #5 |
Drives: 2010 ABM SS Join Date: Feb 2011
Sold 2010 ABM 2SS RS. Kooks, Corsa CB
08-27-2014, 08:49 PM | #6 |
1st Civ. Div.
Thanks, I thought it may have been after looking at the LPE chart above and also doing the math.
08-27-2014, 08:54 PM | #7 |
No Problem buddy! Semper Fi!!
08-27-2014, 09:10 PM | #8 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Damn. That's a great deal especially at 10-lbs. The ATI damper with a 9.5" ring is 13-lbs. Stock is 16-lbs.
08-27-2014, 10:15 PM | #9 |
We still have the steel ones, but I know a lot of guys were wanting to reduce the weight on the nose of the crank. This helps to save a little bit of weight and turn up the boost!!!
08-27-2014, 10:16 PM | #10 |
The 9.45" needs a idler swap at the sane time.
10-06-2014, 10:56 AM | #11 |
Update:
We are adding a 9.65" further down the road guys. Expect them to be several months out though.... |
01-16-2015, 03:15 AM | #12 |
Drives: 14 Camaro ZL1, 87 Grand National Join Date: Sep 2014
Anybody run one of these aluminum pieces yet? Been really considering one.
Vengeance Racing + Cat and Muffler Delete > Viagra
01-16-2015, 07:55 AM | #13 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Are they SFI certified?
Bryan 2018 ZL1 M6
01-17-2015, 06:08 AM | #14 |
11.91 ET Bone stock
Drives: 2015 Camaro ZL1 Join Date: Nov 2014
