Old 08-18-2017, 04:56 PM   #1
Smkn600CTD
Smkn600CTD's Avatar
Drives: 2013 Camaro SS and 2014 SS Sedan
Rear end keeps wanting to break loose in turns or when going WOT
It's weird. Same setup as before with tuner and power. No changes
Got the new wheels 20x10 all corners with the 275s BFG sport comps that I had on my 20x9 square factory wheel setup.
But now if I come around a corner hard or floor it, it traction control pops on, when it didn't before. 45mp and floor it getting i he freeway...Traction control active and it falls on its face then goes. Make a right turn with a little enthusiasm (not 50mph or on the gas), it pops on and feels like the rear wants to snap around.
All that changes was the wheels...unless something went bad somewhere.
Picked up the SS sedan last week...and it seems so much more "confident" driving it with a little gas. Granted it is bone stock power levels and tires.
Ideas?
2016 Lexus GS-F
2014 SS Sedan #2577/3537
2013 Camaro 2SS/RS.
2013 Camro ZL1 Vert
2009 Dodge Daytona Charger #332/400
Smkn600CTD is offline   Reply With Quote
Old 08-18-2017, 08:16 PM   #2
Nzcamaro
NZ Camaro. New Zealand
Nzcamaro's Avatar
Drives: 1968 camaro. 2010 2ss Camaro
i had the same happen but it was straight after my diff oil change, i swapped the oil for another brand and it was good.
tyres may cause it tho
Nzcamaro is offline   Reply With Quote
Old 08-20-2017, 09:59 AM   #3
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Ideas?
Learn better throttle control? Are the BFG's spec'ed to fit a wider rim?
The Stock BFG's that came on my car actually got worse as they wore down. It was nothing to spin the tires on my car and god forbid it was damp or raining out.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 08-20-2017, 11:53 AM   #4
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
are the offsets different?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 08-20-2017, 12:51 PM   #5
Smkn600CTD
Smkn600CTD's Avatar
They are the stock 275 size on all 4 corners
2016 Lexus GS-F
2013 Camaro 2SS/RS.
2013 Camro ZL1 Vert
Old 08-20-2017, 02:51 PM   #6
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
Check the sensors you might have bumped into them? I don't know this platform that well but I know that has happened on other vehicles on forums I've been on. Also I don't know if this would make any difference but are the tire's directional? Are they on backwards? But no check the sensors
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 08-20-2017, 07:23 PM   #7
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Find some new Michelin 295/35/20 SS's and life will be good again!
Old 08-20-2017, 07:40 PM   #8
Smkn600CTD
Smkn600CTD's Avatar
Yeah no joke! These BFGs are noisier than the P-zero too which wasn't supposed to be.
2016 Lexus GS-F
2013 Camaro 2SS/RS.
2013 Camro ZL1 Vert
Old 08-21-2017, 03:22 AM   #9
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Yes. But go with 285's. 295's may not fit up front depending on your offset. Are you running a 275-40-20? A 10" wheel is a little on the large size and will stretch that 275 changing the handling dynamics. I ran 275-40-20's on 10" +23's and when I switched to MPSS's in a 285-35-20 all around there was a world of difference in handling.
SS PANTHER is offline   Reply With Quote
Old 08-21-2017, 06:50 AM   #10
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
It takes all the brightest engineering minds in the world to produce the world's crappiest tires.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-21-2017, 08:41 AM   #11
Smkn600CTD
Smkn600CTD's Avatar
The wheels are 20x10 35 offset all 4 corners
Tires are BfGoodrich G-Force Sport Comp2 275/40/20
I will say this, thinking back, this all started after going from the 20x9 polished wheels to the 20x10's. Same tires were on both set off wheels.
Before the wheels and after the wheel pics....
2016 Lexus GS-F
2013 Camaro 2SS/RS.
2013 Camro ZL1 Vert
Old 08-21-2017, 10:26 PM   #12
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Air pressure too high? What is the hot psi?
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 08-23-2017, 03:10 PM   #13
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
fix the issue yet? Find out what it was?
camarosspower is offline   Reply With Quote
Old 08-23-2017, 04:17 PM   #14
Shoe2ss
Shoe2ss's Avatar
Drives: 2014 2ssrs
are the new rims much lighter?
2014 SS/RS blackwing CAI. LTH. 3inch X pipe exhaust to NPP mufflers. SLP TVS 2300. 1LE strut tower brace. 5.1 short throw shifter. BMR trailing arms. poly cradle mount bushings. 559HP/543TQ
Shoe2ss is offline   Reply With Quote
