#Camaro6
BeckyD @ James Martin Chevy
Old 05-15-2022, 07:52 PM   #1
Drnick
Drives: 22’ ZL1
Snow air deflector?
I’m not quite sure the actual description of this piece of large plastic
That seems to block airflow to the radiator on the 22” ZL1,
But I know there was a post about removal,while looking at
This large part seemingly partially blocking airflow, what is its
Stated purpose?, and can it be removed without negative
Consequences?
Drnick is offline   Reply With Quote
Old 05-15-2022, 08:08 PM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Consequences?
Probably to Block snow or ice. Mines been removed.
I get no water in my intake even washing car. Maybe if it was a downpour and your going 80mph. Other then that it’s pretty useless. Even with it removed it’s still not a straight path.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Camaro1973 is offline   Reply With Quote
Old 05-15-2022, 08:09 PM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Pulled mine a long time ago. I don't track in the rain so I wasn't concerned.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 05-15-2022, 08:35 PM   #4
Drnick
Drives: 22’ ZL1
Thx, but is there a link to remove, I’m not talking about the hood deflector, I’m talking
About the large piece of black plastic in the grill, in front of the radiator.
Old 05-15-2022, 08:42 PM   #5
AZ_1LE
Drives: 2019 ZL1 1LE
Are you talking about the crash bar? They cover it with plastic for looks.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 05-15-2022, 08:51 PM   #6
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Just remove the hood hinge, remove the radiator support, then you'll see the 3 plastic dumb body pins you need to remove. Make sure to have a long body tool to remove them. The bottom one is the pain.
Old 05-15-2022, 09:37 PM   #7
Trochoidal
Drives: 2017 Camaro 2SS A8
Consequences?
Here’s a link on what I did to get to that part and remove it from the car.
https://www.camaro6.com/forums/showp...23&postcount=5
Roto-Fab w/sound tube delete, Katech ported TB, Pray IM, Velossa, DD side markers, DSX FF, UPR Catch can, Halo brace, My custom vent gauge pod
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“
Trochoidal is offline   Reply With Quote
Old 05-15-2022, 09:39 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
remove the piece and snip the blocking piece off and reinstall...pretty easy and it is obvious what needs to be done when you observe where the air enters.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-16-2022, 06:06 AM   #9
Drnick
Drives: 22’ ZL1
Thanks,and what is the exact purpose for this large piece
Of plastic? Decorative to hide something? Or to
Deflect something?
Old 05-16-2022, 06:36 AM   #10
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Deflect something?
We just told you. It’s to help prevent rain/ice/snow from entering intake.
Old 05-16-2022, 10:08 AM   #11
clg82
Drives: 2020 Camaro ZL1
Anyone have a picture of what he's talking about?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21
clg82 is offline   Reply With Quote
Old 05-16-2022, 11:33 AM   #12
Drnick
Drives: 22’ ZL1
Old 05-16-2022, 11:34 AM   #13
Drnick
Drives: 22’ ZL1
That large black piece of plastic
Runs the length of the grille
Old 05-16-2022, 01:29 PM   #14
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
That's the front crash bar. It's got a plastic covering over it. The opening in the photo you posted is for a tow hook in case the car is undrivable and needs transported on a flatbed tow truck.
hawk02 is offline   Reply With Quote
