Old 07-06-2016, 10:58 AM   #1
jdarc1
jdarc1's Avatar
Drives: 2011 Camaro SS
Brakes and rotors
I know this has probably been beaten to death but here it goes. 2011 Camaro SS, I need new rotors and brakes. Whats everyone using for a 600HP car these days. Right now Im OEM rotors with Hawk pads and 32,000 miles, time for a change.
jdarc1 is offline   Reply With Quote
Old 07-06-2016, 11:58 AM   #2
deweyg63
deweyg63's Avatar
Drives: 2011 2SS/RS 500+ h.p. monster
I've got the stock Brembo calipers with ceramic pads and zinc coated, drilled and slotted rotors from Brake Performance. Braided hoses are supposed to give you quicker pedal response but I haven't tried them
deweyg63 is offline   Reply With Quote
Old 07-06-2016, 12:06 PM   #3
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Stock Brembros are probably fine. What makes you think you need more brake than stock?
Thor142 is offline   Reply With Quote
Old 07-06-2016, 01:26 PM   #4
Spec
Drives: 2010 Camaro 1SS LS3
Wearing Powerstop rotors (reasonably priced), but they will require you to turn them prior to installing. Otherwise they will squeel... once done tho, they look great and do the job nice and quiet.
I'm also wearing TRW Ceramic pads.
Spec is offline   Reply With Quote
Old 07-06-2016, 02:10 PM   #5
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
totes bro
I have the brembos calipers with HPS hawk pads, they are noisy as hell after a long drive. Not that I'm braking hard or anything, but these things heat up and then try to embarrass you at your first stop light.
TommyTheCat is offline   Reply With Quote
Old 07-06-2016, 02:15 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Granatelli rotors are one of our favorite brands to use for track or daily driver. Match those with some Hawk HPS 5.0 or HP Plus and you'll have a great set up.
Let us know if you have any questions!
Best regards,
Kayla L.
801.545.4215
Old 07-07-2016, 08:18 AM   #7
jdarc1
jdarc1's Avatar
I know the stock set up is fine, Im just due for new brakes and rotors. The stock setup is $ 1,045.00. Just seeing if anyone else is using something else that is working well.
