09-01-2010, 10:46 PM | #1 |
Drives: 2010 Camaro SS Join Date: Apr 2010
12K miles+ club, how does your clutch feel?
Hello all...
I recently had an occurence with my clutch pedal getting stuck in my SS. Prior to this misfortune, my clutch would normally engage at the top of the stroke (as in, press all the way down, go in gear, lift your foot all the way up and in the last inch of two, she bites). Before, it was ROUGH, as in I could REALLY feel it bite and grip onto the flywheel. There was a DEFINITE feel in the pedal. I know for sure, my clutch ate some serious crap in this event, and got burnt (the smell was horrible). The extent of the damage, I do not know however. I took her into the dealer, and they are insisting it is fine, but the guy at the service desk told me they did not open her up and look to see for sure. In any case, now my clutch is SMOOTH as butter. No bumps, no herky jerky when she catches, and NO DEFINITE feel in the pedal that it is catching. I want to know now, did I damage the crap out of it? Or is this just how a broken in clutch should feel in this car? Thanks in advance |
09-01-2010, 11:32 PM | #2 |
Couldn't tell ya, I occasionally get jerky here and there but I only have 1400 mi on it. I keep hearing about the "clutch stink". What does it smell like ( I know you can't be ultra specific). Once in a great while I think I smell almost like a sweet smell, kinda like new car smell times 50. Is that weird ? lol I can't think of any other way to describe it....
09-01-2010, 11:41 PM | #3 |
Drives: 2SS Camaro Join Date: Oct 2009
Got 8k miles on my car and I can tell you that the clutch is one of the worst that I have ever driven (owned 4 different manuals before this).
The smell happens when the clutch plate heats up. Chevy also released a TSB on it, but the TSB just states that the clutch plate heats up and that it is a driver error. |
09-01-2010, 11:52 PM | #4 |
Thank you for the responses.
I get the smell sometimes too Nashstat, would you be able to comment on the feel of it as well? |
09-01-2010, 11:54 PM | #5 |
Drives: CGM 2SS/RS Join Date: May 2010
I have 8,125 miles on my clutch and it's doing great....I have driven the car hard at times but just be sure to rev match when you are shifting, especially when downshifting, and it will surely save your clutch. I really don't think the clutch is bad, I got used to it pretty quickly.
CGM 2SS/RS, LS3, R2C CAI, Magnaflow exhaust, Black Chrome powdercoated wheels
09-01-2010, 11:57 PM | #6 |
Thanks for the comment TXGooch
Would you mind commenting on how the clutch engagement feels? Does it have a noticeable "bite" when it engages? Or is it just silky smooth? |
09-02-2010, 12:39 AM | #7 |
Drives: 04 sentra, 2ss Join Date: Apr 2009
hi
i have 15k miles my SS and ever since i got the new throwout bearing its been shifting good, before that stuck clutch pedals and herky jerkies. I dont know how much damage was caused due to the throwout but when this one burns out ill get the zr1 clutch. joey |
09-02-2010, 12:55 AM | #8 |
Drives: 2015 c7 Join Date: Nov 2009
the camaro stock clutch is junk, i want a new clutch and axles.. is the zr1 clutch out for the camaro ? and who is selling it
09-02-2010, 01:06 AM | #9 | |
The tech at the stealership said it's normal... Googled it up, apparently many peeps are facing the same issues in Corvettes. Just looks like GM used a cheap clutch! |
09-02-2010, 06:09 AM | #10 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
I've got just under 7K miles on mine and it feels like butter since the last 5K. I like it much better after the newness is wore off. No stink here, just grabs top 1/3 of peddle and goes ...
09-02-2010, 07:21 AM | #11 | |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
09-02-2010, 08:05 AM | #12 |
21k miles, my clutch stuck in one time at around 8k miles when i was "racing" hasnt happened since. and it feels fine
09-02-2010, 08:05 AM | #13 | |
Drives: '10 Camaro SS Join Date: Apr 2009
OP: My clutch gets pretty smelly from allot of first gear stop and go in heavy traffic. Clutch still works like new though with 15K miles on it. The only time the clutch has stuck to the floor has been at the drag strip from hard launches with too much RPM (4K or above) Launching at 3K to 3500 and riding the clutch out like leaving normally from a stop light the clutch has not stuck.
2010, SIM, 2SS/RS, LS3, CGM Stripes
09-02-2010, 08:25 AM | #14 |
Drives: 2SS LS3 Join Date: May 2010
This issue has been described many times. Do a forum search. In some cases the clutch was replaced, in others, the dealer/GM claimed it was the driver's abuse. Take it to another dealer if you have to.
2010 CGM 2SS LS3, born: 4/10 |
Similar Threads | ||||
Standard vs Automatic | MyCamaro5 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 153 | 07-24-2019 11:24 PM |
Camaro Clutch Pedal Feel? | msqr | 5th Gen Camaro SS LS LT General Discussions | 37 | 11-24-2015 09:30 PM |
Best way to learn how to drive a stick? | Beitzel15 | Off-topic Discussions | 21 | 06-24-2009 11:31 AM |
New to the Stick...Advice? | NightmareSS | 5th Gen Camaro SS LS LT General Discussions | 101 | 06-19-2009 09:24 AM |
