05-21-2011, 08:43 AM | #1 |
MURC 666
Drives: 69 Pace Car 68 Camaro Restomod 81 Z Join Date: Jan 2010
FI spark plugs
what are the best spark plugs to run with forced induction? I installed the tr6 everyone seems to run but there must be something better out there in the approriate heat range .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it ! |
05-21-2011, 10:07 AM | #2 |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
All depends on how much power you are making... I run a NGK BR7EF.. and I am n/a
05-21-2011, 01:21 PM | #3 |
Drives: black on black 2SS/RS Join Date: Feb 2010
yeah depend on the hp you running i always use ngk #8 or #9
05-21-2011, 04:03 PM | #4 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2009
ngk's are some of the best.
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst- Mods: Corsa catback, SSE, Vararam |
05-21-2011, 11:13 PM | #5 |
173rd Paratrooper
Drives: Summit White SS Join Date: Aug 2010
Ted at Jannetty swears by stock plugs but we use NGKs in our customers cars. My car is using properly tapped stock plugs and runs just as well as TR6s at 700+rwhp.
Jeramey - 715rwhp
Vortech YSI - 10Rib CTS-V Dual Fuel Pumps American Racing Headers Thunder Racing Cam Walker Bullet Exhaust DSS 1400hp Axles Barton Industries Shifter ADM Boost/AFR Gauges |
05-23-2011, 02:44 PM | #6 |
Drives: '88 Monte Carlo SS, '10 Camaro SS Join Date: Jan 2010
The Tr6 is a great plug, the only common plug i'd recommend over them is the NGK Iridium series, p/n TR6IX. When the TR6 couldn't keep the fire lit, we always saw cleaner runs with the Iridiums.
-Chris
'10 Camaro SS '88 Monte Carlo SS |
05-23-2011, 03:11 PM | #7 |
Drives: Pontiac Firebird Join Date: Apr 2011
In every Nitrous application and in most FI combination's, I would run a non-projected tip plug. This going to open the tuning window and is simply the correct plug to run.
Heat range will vary based on the aggressiveness of the entire combination. Dynamic compression ratio, boost level, fuel type, and size shot of nitrous. There are 2 company's plugs I really like. NGK - One of the big plus's to their plugs is the cadmium they plate there plugs with is pretty soft. It makes plug reading easier than an equivalent Autolite or other brand. Also if you nip a plug they might not tear up the cylinder. If you do that on a hard strap plug, it pretty much guarantees engine damage. They are also reasonable enough in price you can buy a few sets to get good reads. Also, I would run a Br6ef plug in every FI/nitrous application in place of the tr6. The tr6 was simply the only plug option when it came out. There are simply better options that are priced the exact same that can be bought at the same places. Brandon@NGK is extremely knowledgeable. I use him as a reference when I start messing with a new platform or I get a wild combination I am unfamiliar with. If anyone would like his direct line let me know. Brisk - High end bad ace plugs. These guys have stepped in a few markets where we could not get other manufactures to do so. They quality on these things is great. They do cost a lot however. Really nice plug especially if you already have your tune dial in. Last edited by Graham@N; 05-23-2011 at 05:52 PM. |
Similar Threads | ||||
E3 Spark Plugs for SS | jmlozano7 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 38 | 06-11-2016 08:22 PM |
What type and heat range are the stock LS3 spark plugs? | topgun1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 06-29-2010 10:45 AM |
spark plugs | Gr8_syder | 4th Generation Camaros | 1 | 04-11-2010 08:12 PM |
