05-24-2012, 06:20 PM | #1 |
Drives: 2012 2LT/RS 6L50 automatic TF-3 Join Date: Apr 2012
2012 V-6 automatic
What is the correct model number for this transmssion and also what is the max. torque for this unit? Any help is appreciated... Thanks
05-27-2012, 04:28 PM | #2 |
Drives: 2011 2LT RS Blk/Blk Join Date: Dec 2011
2012 V-6 automatic
To verify the transmission in your car, check the build label located in the trunk on the driver's side. The transmission codes are:
1) 6L45 = MYA 2) 6L50 = MYB 3) 6L80 = MYC 4) 6L90 = MYD Sorry, the factory service manual doesn't list the Max torque. |
06-30-2012, 12:49 PM | #3 |
Thanks for the info . I have the 6L50.
Its better to burn out , than to fade away.
07-04-2012, 08:28 AM | #4 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
The 6L50 is adaptable to rear-wheel drive and all-wheel drive applications. It can accommodate engines with up to 332 ft·lbf (450 N·m) of torque, and vehicles with a GVWR of 5,000 lb (2,268 kg).
Gear ratios: 1 2 3 4 5 6 R 4.06 2.37 1.55 1.16 0.85 0.67 3.20 |
07-23-2012, 09:55 AM | #5 |
Thats what I needed thanks guys!
