03-10-2015, 08:38 PM | #1 |
Drives: 2015 AGM 1SS/RS/1LE NPP Join Date: Dec 2014
Threatened by Hedricks Chevrolet service department
Fresno, CA
Heres my experience I dropped off my 2015 SS Camaro because it was having a stabilitrak warning message and a CEL. After diagnosing the problem they told me it was a throttle position sensor but blamed it on a minor aftermarket modification I have called a Vitesse Throttle Controller. The real issue was that Carol threatened to notify GM and get this... place a salvage title on my 2015 car. What kind of customer service is this? you threaten your customers who make one minor modification to their car? If all the camaros in the world got salvage titles for modifications then 95% of all camaros would be carrying salvage titles. Obviously Hedricks is NOT a mod friendly dealership. Any car enthusiasts who have anything done to their car should NOT use the service department at this dealership. In addition she was going to rotate my stock tires on my 1LE which have larger wheels in the back than the front - When a service department doesnt even know how to service stock vehicles or differentiate between models, there is a problem. Steer clear of this service department.
03-10-2015, 08:40 PM | #2 |
Drives: 2015 Camaro SS 1LE Join Date: Dec 2014
Where are tbeh located? Off Shaw Ave?
03-10-2015, 08:41 PM | #3 |
'It's an experiment'
Wow...
Glad you got out of there. This is why I try to do all I can myself -- learning OBD II and Mode $06 diagnostics... Having a Tech2 and MDI helps -- but the damn subscription is $3k a year! Hope you find a better dealership -- they are out there... -Don
747 RWHP 794 RWTQ
03-10-2015, 08:47 PM | #4 |
03-10-2015, 08:50 PM | #5 |
is anyone else having trouble with a VTC, CEL and engine power reduced?
03-10-2015, 08:56 PM | #6 |
I have it on mine and I've not had any issues. I do change it SP 0 when I don't 'want' to have fun. No CEL -- but I'm an 11 2SS...
-Don
747 RWHP 794 RWTQ
03-10-2015, 09:30 PM | #7 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Not sure how a dealer can "place a salvage title", but they can flag your car in the GM system as modified
03-10-2015, 09:41 PM | #8 |
Devices like this should be taken out when visiting the dealer. That's the reason for such plug and play mods instead of tuning. Better yet, you should have taken out the only mod you had to the car and seen if it went away first.
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
03-10-2015, 09:43 PM | #9 |
Got Boost?
Drives: 2011 1SS/RS M6 SLP TVS 2300 Join Date: Oct 2010
Not the first time ive seen a bad review on that dealership sorry you had to deal with that. Take your VTC off and see if your cell clears, if so you have found your issue. However from what i have read the VTC shouldn't cause any issues. I always tended to steer clear of the all the dealerships in fresno.
2011 1SS/RS M6
MOD List: SLP 2300 Supercharged, Flowmaster AT Cat back, aux 4 guage cluster, 12" kicker sub and Kicker Zx400.1 amp, PFADT Lowering springs CAI Inc. CAI, Hurst Short throw shifter, JBA 1 7/8 Long tube headers. Future Mods: 416ci stroker. |
03-10-2015, 09:49 PM | #10 |
I don't believe she can alter my title but what a stupid thing to threaten the customer with such a thing. I'm going to delete the vtc and monitor it for awhile. Just wanted to give people a heads up about the dealerships attitude
03-10-2015, 10:03 PM | #11 | |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Yes it has happened to me about 3 times now and it always happens when I'm using my paddles... And I've had my throttle controller for about 5-6 months it just started doing this. I contacted vitesse motorsports and one of the guys said it might be that my throttle body was dirty or that the wires aren't plugged in all the way. I did both and just about an hour ago it happened to me coming home. Luckily I had my scanner to clear it.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
03-10-2015, 10:32 PM | #12 |
Drives: 2011 RS Join Date: Apr 2011
I thought that the 1LE had a Squared wheel set up and the ZL1 had the staggered wheels.
03-10-2015, 11:26 PM | #13 |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
Any aftermarket mod can void a warranty, if GM can prove it as the cause of the failure. The Throttle Controller does not leave any imprint on the ECU's memory, Therefore, it is untraceable and cannot be blamed for a failure.
GM cannot prove you ever had it hooked up. If you ever have a failure and have to take it to the dealer for repair... just disconnect and remove the device and plug the factory harness back into the gas pedal. |
03-10-2015, 11:40 PM | #14 |
20x10 on the front 20x11 on the rear
