01-27-2014, 03:44 PM | #1 |
Drives: camaro 2ss 2012 Join Date: Dec 2013
Will 3.91 Gears void warranty?????
I am thinking about getting 3.91 gears on my camaro ss 2012. But i was wondering if it would void my warranty i hear it will not than i hear it will. I also hear that if the dealership were to do it, it should not void warranty and they will do the tune as well to fix the speedometer and the calibration. Will i just need to order this and ask to get them installed by the dealer for the warranty wont be voided or may be ????????
http://www.partstaxi.com/products.php?partID=1644 http://www.phastekperformance.com/20...l380041410.htm |
01-27-2014, 03:50 PM | #2 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
GM can void your drive train warranty for any tune done by anybody. The gear itself will void the warranty on the parts you are changing.
01-27-2014, 03:55 PM | #3 | |
Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
GM can still make the assertion that the failure was due to mods however. What they can't do is not cover the power window switch if you put 3.91 gears into your car. To the OP, Magnuson-Moss, google it.
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
01-27-2014, 03:55 PM | #4 |
so technically if the gears cause the problem its not covered under the warranty so technically i got that part down but cant you buy like an sct tuner and tune it yourself and when needing to go get the car checked out cant you return it to factory setting and they wont be able to tell its tuned??????
01-27-2014, 04:01 PM | #5 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
??? How would they KNOW they were even in the car unless they Open the rear end transfer case
01-27-2014, 04:12 PM | #6 | |
http://www.chevrolet.com/performance/camaro-parts.html |
01-27-2014, 04:24 PM | #7 |
Drives: '14 1LE Join Date: Nov 2013
The GM 3.91 gear does NOT automatically void your warranty. Explain the situation to your dealership, including the fact that GM advertises this gear as an upgrade to the SS that will not void the powertrain, and see what they will do for you.
I have the GM 3.91 gear, waiting to be installed, and asked my dealership about it. Long story short, I have a communication from the GM regional manager agreeing that having a performance shop (not dealership) install the gear and perform the recalibration will not void my powertrain, although they may not warranty the gear itself if not installed by the dealership. |
01-27-2014, 04:34 PM | #8 |
ok cool thanks so if the dealership were to do it all than it wont void any warranty but can the dealer do the re calibration????
01-27-2014, 04:35 PM | #9 | |
The recalibration requires a flash of the ECM and if that flash isn't done & registered by a GM dealer, then the flash can't be confirmed as a speedo recalibration-only change and thus your power train warranty is subject to be voided. |
01-27-2014, 04:37 PM | #10 |
Drives: 2SS/RS Join Date: Sep 2008
If installed and calibrated by a GM dealer, they will not effect your 5 year/100k mile power train however it will replace the 5 year warranty with a 1 year/12k mile warranty the gears come with. So your power train will still have the 5 year warranty but the rear end will only have a 1 year warranty.
Now here's the kicker that GM doesn't tell you. At this time, the GM calibration is NOT available. GM has been saying since last summer that it's coming but it's still not out for the techs to use to reflash your car so your only options is a aftermarket tune which will void your warranty. |
01-27-2014, 05:04 PM | #11 |
My dealer can't do the recalibration on-site. They would have to obtain data from my car, send it off to GM, then get it back and apply to my car...total cost of $200-300. Too much time and cost IMO. Honestly, I'm hoping the GM calibration becomes available before I get ready to have the gear installed, so I don't have to worry about haggling with the dealer in the future.
I have been asked before to provide a copy of that email from the GM district manager, but I don't plan to do that because I'm not entirely certain it would do you any good, and I want to maintain a good relationship with my dealership (...and I'm not interested in providing it just to prove that I'm telling the truth - believe me or don't). I recommend you open the discussion with your dealership, explain the situation, the fact that GM advertises/recommends the part as an upgrade to your car that won't void your warranty, and see where you can get. Ultimately, each dealership decides what they will and will not do, but in my experience you have to challenge their initial "that voids your warranty" response before you can actually make progress. Best scenario IMO - you get the gear install and speedometer recalibration done by your dealership. In my situation, the dealer isn't comfortable doing the gear swap, and can't do the recalibration themselves, so I'm looking at other options. |
01-27-2014, 05:36 PM | #12 | |
01-27-2014, 06:19 PM | #13 |
so at the moment the dealers don't know how to do the recalibration?????
01-27-2014, 06:36 PM | #14 |
It's worth asking your dealer. One guy on the forum says his dealer received the capability to do an official GM recalibration, and only charged him $50. I haven't been able to independently verify...my dealer certainly couldn't figure it out.
