07-12-2014, 10:10 PM | #1 |
COTW 6/16/14
Drives: 2014 CRT Camaro ZL1 Join Date: Feb 2014
Weird Problem From Track Day!?
Took the ZL1 to the road course track for the first time today. All went well for the first few sessions, but then started to hear something sliding left to right and right to left under hard turns and corners.. Nothing in trunk sliding around sounded like under the car in the rear.. I pretty sure it is all "noise" not "feel" car still tracked well but could here something sliding only under turning hard not accel or braking.. Anyone know what this could be.. checked lugs on wheels and nothing was loose.. Car is at 510 race engineering now. Anyone have this issue or know what could be up?
Thanks!!
Not Enough Traction // Build Thread Below
http://www.camaro5.com/forums/showthread.php?t=356576 2014 ZL1 |
07-12-2014, 11:35 PM | #2 |
If you're sure nothing is sliding around I would ask what PTM mode you ran in? It didn't sound/feel like rear brakes being applied? Did you change the rear diff fluid...proper LSD FM was added?
Sent from my iPad using Tapatalk |
07-12-2014, 11:53 PM | #3 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Nice to meet you today, cant wait to see the build...
07-13-2014, 12:15 AM | #4 | |
COTW 6/16/14
Changed the brake fluid thats it.. PTM Mode 3, sliding with brakes applied and without
07-13-2014, 12:15 AM | #5 |
COTW 6/16/14
Nice meeting you too! Ill be down again sure enough today was killer!
07-13-2014, 12:31 AM | #6 |
ROAD COURSE JUNKIE
Make sure your battery and compressor are not lose.
07-13-2014, 12:32 AM | #7 |
COTW 6/16/14
battery was locked down tight
07-13-2014, 06:43 AM | #8 |
ROAD COURSE JUNKIE
Well then I would put it on a lift and make sure everything on the car is tight.
Not sure what it could be.
07-13-2014, 07:21 AM | #9 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Fuel?
how much did you have left in the tank?
07-13-2014, 08:26 AM | #10 |
Drives: none Join Date: Aug 2011
07-13-2014, 08:31 AM | #11 |
Between wind noise and the motor I've never heard much more.
07-13-2014, 09:55 AM | #12 |
COTW 6/16/14
fuel was about 3/4 full it wasn't that.. noise was like sliding then hitting something then sliding back and hitting the other side. like in a straight line not sloshing. Thanks for the feedback
07-13-2014, 09:56 AM | #13 |
COTW 6/16/14
thats what I'm thinking.. its getting work done to it at 510 racing so they will be checking it out as well..
07-13-2014, 10:18 AM | #14 |
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1 Join Date: Feb 2012
Glove box? . . . My wife and I were going nuts trying to find a clunk in her rag top . . was the bag of documentation sliding back and forth.
Our Garage:
2018 Traverse High Country, 2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . . |
