06-15-2012, 02:11 PM | #1 |
Drives: Black 2012 Camaro ZL1 #740 Join Date: Nov 2011
Does a ZL1 Warranty cover track use?
I was at the drealer I purchased my ZL1 from the other day, and got in to a conversation with one of the service guys.
He asked me if I opened her up yet?? I said not yet but I will take it to the strip at least once to see what it will do. he said don't break it cuz parts are expensive...i thought the warranty did cover track use (with-in reason and no mods). Can anyone give me confirmation?? Thank you!! I trust C5 members more than him... |
06-15-2012, 02:13 PM | #2 | |
Drives: 2013 F-150 Limited Join Date: May 2008
EDIT: Added some sections of the manual that talk about tracking your car. For vehicles with this gauge, it is near the shift lever and indicates engine oil temperature. If the gauge pointed moves to the higher end of the gauge, the engine oil temperature is operating hotter than normal. It is acceptable if this happens during aggressive driving or racetrack usage. The DIC will display a warning message if the engine oil temperature exceeds an acceptable level. This gauge indicates the engine coolant temperature. If the gauge pointer moved to the H or the shaded area, the engine coolant is operating hotter than normal. It is acceptable if this happens during aggressive driving or racetrack usage. The DIC will display a warning message if the engine oil temperature exceeds an acceptable level. PERF TRACTION 1 – WET ACTIVE HANDLING ON SUSPENSION MODE TOUR (ZL1 Only) This message displays when this Performance Traction Management mode is selected. The instrument panel cluster light will also be on when this mode is selected. Once this message is acknowledged, PTM1 – WET ESC = ON displays on the bottom of the digital speed page. Launch Control is available when this mode is selected. In this mode, the Traction Control and Active Handling System are available but intended for use on wet race track conditions. Adjust your driving accordingly. Racing/Track Brake Burnish ProcedureNotice: Brake pedal fade will occur during this track burnish procedure and can cause brake pedal travel and force to increase. This could extend stopping distance until the brakes are fully burnished. 1. Apply the brake 25 times starting 100 km/h (60 mph) to 50 km/h (30 mph) while decelerating at 0.4 g. This is a medium brake application. Drive for at least 1 km (0.6 mi) between applying the brake. This first step may be skipped if there are more than 200 miles (320 km) on the brake pads. 2. Repeatedly apply the brakes from 100 km/h (60 mph) to 25 km/h (15 mph) while decelerating at 0.8 g. This is a hard brake application, without activating the antilock brake system (ABS). Drive for at least 1 km (0.6 mi) between stops. Repeat until the brake pedal travel starts to increase. Depending on conditions, this should take no longer than 25 brake applications. 3. Cool down: Drive at 100 km/h (60 mph) for approximately 15 km (10 mi) without using brakes. 4. Apply the brake 25 times from 100 km/h (60 mph) to 50 km/h (30 mph) while decelerating at 0.4 g. This is a medium brake application. Drive for at least 1 km (0.6 mi) between applications. Competitive Driving Mode Competitive Driving Mode, Performance Traction Management (PTM), and Launch Control are systems designed to allow increased performance while accelerating and/or cornering. This is accomplished by regulating and optimizing the engine, brakes, and suspension performance. These modes are for use at a closed course race track and are not intended for use on public roads. They will not compensate for a driver’s inexperience or lack of familiarity with the race track. Drivers who prefer to allow the system to have more control of the engine, brake, and suspension are advised to turn the normal TCS and StabiliTrak systems on. Performance Traction Management (PTM) (ZL1 Only) PTM integrates the TCS, StabiliTrak, and Selective Ride Control systems to provide improved and consistent performance when cornering. The amount of available engine power is based on the mode selected, track conditions, driver skill, and the radius of each corner. PERF TRACTION 2 – DRY / ACTIVE HANDLING ON . For use by less experienced drivers or while learning a new track. . Dry conditions only. . StabiliTrak is on and engine power is slightly reduced based on conditions. PERF TRACTION 3 – SPORT 1 / ACTIVE HANDLING ON . For use by drivers who are familiar with the track. . Requires more driving skill than mode 2. . Dry conditions only. . StabiliTrak is on and more engine power is available than in mode 2. PERF TRACTION 4 – SPORT 2 / ACTIVE HANDLING OFF . For use by drivers who are familiar with the track. . Requires more driving skill than modes 2 or 3. . Dry conditions only. . StabiliTrak is off and available engine power is available is the same as mode 3. PERF TRACTION 5 – RACE / ACTIVE HANDLING OFF . For use by drivers who are familiar with the track. . Requires more driving skill than in other modes. . Dry conditions only. . StabiliTrak is off and available engine power is available for maximum cornering speed. Use mode 5 for most consistent performance during drag strip use. When the TCS/StabiliTrak button is pressed again, the vehicle exits PTM mode and the TCS and StabiliTrak systems are on. ZL1 Only: For racing or competitive driving, it is recommended that the loading of the vehicle be limited to the driver only, with no other cargo, and that tires be inflated to at least 180 kPa (26 psi). If the vehicle is used for racing or other competitive driving, the rear axle fluid temperatures may be higher than would occur in normal driving. We recommend that the rear axle fluid be drained and refilled with new fluid after every 24 hours of racing or competitive driving. See Recommended Fluids and Lubricants on page 11‑12.
There just might be a 2016 Camaro or Corvette in my future...
_____________________________________________ Previous Chevy's 2013 Camaro ZL1 A6|SIM 2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int 2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed 2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned Last edited by JMAN311; 06-15-2012 at 02:21 PM. Reason: added entries direct from manual |
06-15-2012, 02:16 PM | #3 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Read your warranty, IMO if it's not in black and white it's not covered.
06-15-2012, 02:41 PM | #4 | |
06-15-2012, 03:46 PM | #5 |
Drives: 12 ZL1 & 08 Suzuki Boulevard C50 Join Date: Oct 2011
Watch theses videos
http://www.camaro5.com/forums/showthread.php?t=220554 These will answer your questions also.....
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
06-15-2012, 04:18 PM | #6 |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
Yes.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me. |
06-15-2012, 08:09 PM | #7 |
Drives: 2011 Camaro Convertible SS/2012 ZL1 Join Date: Feb 2011
I sat-it on the webcast and that question came up. With a pause and a laugh they said quote:" Yes, GM would warrant the car if used for track use as long as you don't get STUPID with the car". What their meaning of "stupid" is is anyones guess.
06-15-2012, 08:15 PM | #8 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Its your insurance you have to worry about, if they find out you hit the wall at a track, they will deny coverage.
06-15-2012, 08:23 PM | #9 |
Drives: Camaro Justice Join Date: Jun 2007
Running laps at an HPDE -- Covered by Warranty
Racing at the same track in a two hour event -- Not covered Drag Racing at the Local Track -- Covered Drag racing on full slicks with the seats removed and a cage -- Not Covered Drag launches in the ZL1 using the on board computer are covered. Turning everything off and popping the clutch at 6,250 on slicks in not covered. Maybe an easier way to clarify the warranty on the ZL1 is if you think what you plan to do next is not covered, it probably isn't. |
06-18-2012, 07:22 AM | #10 | |
Drives: GM Vehicles Join Date: Jun 2010
Damage Due to Accident, Misuse, or Alteration The New Vehicle Limited Warranty does not cover damage caused as the result of any of the following: Misuse of the vehicle; such as driving over curbs, overloading, racing, or other competition. Proper vehicle use is discussed in the owner manual. I hope this information was useful. Brandon Chevrolet Customer Service
06-18-2012, 07:40 AM | #11 |
Opinionated bugger!
Drives: Boss 302, Mazda 2, Praga & Intrepid Join Date: Feb 2011
Track days are not racing.
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles |
06-18-2012, 08:17 AM | #12 |
COTW 5/06/2013
but "other competition" may be seen as track days where you are competing for better times
06-18-2012, 07:05 PM | #13 |
Opinionated bugger!
Competing against ones self is not competition. My dealer knows I track. Non issue. But I suppose he could suddenly become a prick. Still unless there is track damage from an impact in not concerned. So as GM advertised publically as covered, I'd think you guys are all covered.
06-19-2012, 09:56 AM | #14 |
Drives: 2007 Shelby GT500 Join Date: Oct 2008
I heard insurance will cover damage if done on practice or track days, but not during a race or competition runs. Can anyone confirm this, or is this specific to different companies insurance policies?
2015 Mustang GT "Cam only"
