11-29-2014, 09:12 AM | #1 |
Drives: ZL1 Join Date: Oct 2013
Heat exchanger upgrade?
Hey guys...in a few weeks I'm doing some healthy mods. Going with a cam, upper pulley, Bosch 80 lb injectors, lingenfelter twin fuel pump, long tube headers, and a coolant reservoir. My question is: is a new heat exchanger required right now? I haven't road coursed the car and don't plan to. The most it will see is highway pulls and maybe a few passes at the strip with time to cool off.
11-29-2014, 08:19 PM | #2 |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
If that is how you intend to use it then I would say no especially if you do give it time to cool off between runs. Once you decide to start tracking the car then I would say you would want to do the heat exchanger but this is just my opinion. I track and autoX my car alot so it was one of the first things I did.
Life is too short to drive cars that suck.
My build Thread |
11-29-2014, 08:30 PM | #3 |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
Personally, I would say go for it while you have everything pulled apart. I don't track nor drag but I find myself WOT quiet a bit and these cars heat up fairly quickly. It's nice to get that quick recovery while driving or while cooling down.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
11-29-2014, 09:18 PM | #4 |
Drives: 2018 GT350 Join Date: Nov 2011
What heat exchanger would you recommend? And are you saying that if you autocross it stock you would do the upgrade? Or only after modding?
Off to the Dark Side
11-29-2014, 09:50 PM | #5 | |
I have the Ron Davis Heat Exchanger which is doing a great job with the recovery. As for needing it for auto cross. I am no expert but I wouldn't think it would be a needed upgrade for auto cross.
11-30-2014, 12:41 AM | #6 | |||
In my opinion, with your planned mods your at the borderline for needing a better HX, as Camero5 said, it's going to all be pulled apart so if you got the money then go ahead and do it, that way you are facilitating future mods now. If you wait, I'd definitely do it before doing anything else after these.
My build Thread |
11-30-2014, 05:13 AM | #7 |
Drives: '21 ZLE A10 Join Date: May 2012
Ron Davis or LPE with fans. I have a Cooler Logic unit but they are out of business.
11-30-2014, 03:17 PM | #8 | |||
Drives: 2013 ZL1 M6 Join Date: Jan 2014
What App did you use to overlay the engine parameters on the video? It was interesting to see the IATs drop as the speed speed picked up. As soon as you stopped at the end the IATs started rising very fast. I have the Ron Davis H/E and Ron Davis Radiator in my ZL1.
Corvette Z06/Z07/M7 (2016) Late Model Racecraft Intercooler reservoir and 160* Thermostat.
Sold- 2013 Camaro ZL1 M6 (Black on Black), Detroit Speed Sway bars, DOT 4 Brake Fluid, separate clutch master reservoir, Moroso Catch Can. 2.11 at Thunderhill 100* ambient. Ron Davis Radiator and AFCO Heat Exchanger installed after track day, Roto-Fab CAI. Sold- 2001 Mustang Cobra -Griggs GR40,M5, Torsen T2-R, 4.10, 14" Brembo fronts, high 1:40s at Laguna Seca |
11-30-2014, 05:42 PM | #9 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
With that list of mods I would upgrade the heat exchanger. Hard to say which replacement is the best choice. I have the Ron Davis and it is excellent.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
11-30-2014, 07:54 PM | #10 |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Adding a reservoir is also a good idea. Even if you don't change the heat exchanger a reservoir will help a lot. It's added capacity since the stock system hold so little coolant. More coolant means it takes longer to heat up.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
11-30-2014, 11:24 PM | #11 | |
More Info: http://forum.racerender.com/viewtopic.php?f=8&t=209 http://www.camaro5.com/forums/showpo...8&postcount=14
My build Thread |
12-01-2014, 07:31 AM | #12 | |
Drives: 2018 Summit White Camaro 1SS Join Date: Mar 2014
12-01-2014, 09:21 AM | #13 |
Track > 1/4 Mile
I regularly track my car and use the Ron Davis heat exchanger. I'm running around 11.5 lbs of boost (upper only) and have zero heat issues running ~30 minute sessions.
For what you're doing it probably isn't necessary but definitely would be an improvement.
12-01-2014, 09:57 AM | #14 |
Going for Plaid
What size upper?
Thread Tools | |
