01-25-2014, 05:16 PM | #1 |
Drives: 2012 2LT Join Date: Aug 2013
ZL1 exhaust
My first post on this site. Just pick up a ZL1 exhaust today. I will compare (configation)in the morning how much work I need to make it works on my v6. Has any one done this modification. I know I need suggestion on where to tap for vacuum. Thank you in advance.
jack |
01-25-2014, 07:12 PM | #2 |
Drives: 2013 Cammed/LSA Conversion 1LE Join Date: Mar 2013
I hope this install in very easy for you! Looking forward to hearing this setup! but welcome to the family.
"Livin' life in the fast lane, moving at the speed of light and I can't slow down, only got a gallon in the gas tank, but I'm at the finish line so I can't stop now"
01-28-2014, 07:18 AM | #3 |
Same configuration
I checked the layout, they look like it is a direct bolt-in. Can't wait to install the new look and sound.
Jack |
01-28-2014, 08:42 AM | #4 |
ZL1 Exhuast
How Can I get this For my RS?
01-28-2014, 12:12 PM | #5 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I don't think bolting on is the hard part. Making the dual mode work with the vaccum and controller module is the hard part. You'll need more than just the vaccum lines to make it all work properly....its can be an expensive project.
Best of luck to you!
2010 Camaro 1LT V6 (Sold. I will miss her!) |
01-28-2014, 01:08 PM | #6 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Isn't the ZL1 exhaust a 3" system?
01-28-2014, 02:41 PM | #7 |
Exhausts are 2 1/2"
Both exhaust are 2 1/2". As it is an alternate add on to my exhaust system. I have two options in my mind.
Leave it open all the time Add an NPP in a box, it does not have to run as factory design. I can open/close the flip with a switch Do you think my idea would work. Jack |
01-28-2014, 03:39 PM | #8 | |
01-28-2014, 11:30 PM | #9 |
Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
Definitely want to hear this thing! A controlled switch in the cabin could be pretty cool but whichever works best for you! Keep us updated, sounds like a cool project.
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear |
01-28-2014, 11:54 PM | #10 |
Drives: 2012 ZL1 #141 Join Date: Nov 2011
Pretty cool. I have not heard of anyone doing it yet. Please post youtube or sound when you are done.
02-08-2014, 02:01 PM | #11 |
It's done and I like it
I started early this morning. While the four tires are removed, I change out the brake fluid before my friend arrive.
I was not able to remove the diffuser, but the bumper removal was easy. It takes less than 15 min to remove my existing exhaust, and install the ZL1 exhaust. The next step was to trim my diffuser. I hook the bumper back with a string to use as a template. The cutting is not perfect, but I don't think it's noticeable. It sounds loud at 1st and 2nd gear, smooth at higher gear. It still loud even with a wire is used to close the exhaust gate. Jack |
02-08-2014, 04:41 PM | #12 |
KaBoom1701
Sweet.
Post some videos!
Mods:
02-08-2014, 05:24 PM | #13 |
When you get the setup done definitely take some good videos if you can. Oh, and please keep the recording device a little ways back from the exhaust (10 - 20 ft)...don't jam it right up next to the tailpipe lol.
Driving vids are always better though...these cars sound better under load rather than free revving.
02-13-2014, 01:54 PM | #14 |
Drives: White 2012 Camaro 2Lt RS Join Date: Jun 2012
Video please for sure!!!
2012 White Camaro 2Lt RS w/t ZL1 Front end and side skirt conversion, Flowmaster AMT Cat-Back, JL 12w7, Viper 3303 security w/t proximity, glass break, and tilt censors, K&N Cold Air Intake, and Cobra xrs-9970g, LED Glow Advanced 3Million Kit
