06-22-2017, 07:32 PM | #1 |
Drives: 2013 Camaro Join Date: Jun 2017
Spare tire for 5th gen camaro SS
So after buying my SS I was a little shocked to hear that GM did away with the spare tires on them. A guy in my local club told me that they just come with a little air compressor and this goop type stuff. WTH GM!! Anyways I do a lot of long distance driving in a desert area for work and getting stranded from a flat is not an option for me. Considered AAA, but then again I don't want to wait a couple hours for them in the heat.
I found a rather slick set up from a company online who manufacturers spare tire kits for our cars. I spoke to them today and they say the whole kit will fit in the spare tire well. Looks like you can also buy it with a carrying case. I was concerned about the wheel fitting over the Brembo's but they assured me that it has plenty of clearance for it. Has anybody bought this? Thoughts? I wish I could post a link to their site and the price but I'm not sure if they are a supporting vendor so rather here's a bit of copy and pasted info. -Conveniently Fits Inside Trunk Tire Well With Minimal Deck Lid Lift (Less Than .5”) With All Necessary Mounting Hardware Included. -18×4 Aluminum Alloy Wheel With 5x120MM Bolt Pattern. Pirelli T135/80R18 Tire W/81 MPH Speed Rating – 26.5” Rolling Diameter For Safe Extended Vehicle Use. -3000 LB TruLift Ratcheting Scissor Jack With Rubber Contact Point -Modern Spare 14” – 21” Telescoping Lug Wrench With 17MM, 19MM, 21MM, & 22MM Sockets. -Large Disposable Tire Bag Included For Full Size Tire Transport |
06-22-2017, 07:38 PM | #2 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
im guessing that the foam piece that holds the air pump and goop package is deleted to make room for the tire? if you could PM me with the details on this i would probably buy one for my 2015 RS.it is crazy not to carry a spare and jack...
06-22-2017, 07:48 PM | #3 |
Drives: 2013 Join Date: Mar 2017
had same problem with wifes 2013 SS...google at company called Performance Spare. this guy has the set up for SS...fits over the brakes with no issues or spacer,,,fits in trunk with no issues...his price is $300 well worth it...other members have discussed this company before ...hope this helps
06-22-2017, 08:10 PM | #4 | |
06-22-2017, 08:12 PM | #5 |
Yup, that foam piece just slides right out. Definitely worth the $300 for the spare. I'll get you a PM sent in a couple minutes.
06-23-2017, 06:29 AM | #6 | |
Drives: 2014 2SS/RS Join Date: Dec 2014
Cover is shown in pic installed over battery below, the tire is slid over to expose. Diagram part#6 Upper Cover > 22968661 (I use the factory spare tire kit kept when I traded in last Camaro and wheel adapter to clear the Brembo rollerskates). Have seen new jack for $35 or cheaper used off ebay. OP, be good to double-check that they guarantee the fancy spare wheel will indeed fit over the Brembo caliper/pads that have the big roller skates sticking way up on the front calipers - it takes a big wheel to clear those.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
06-23-2017, 09:40 AM | #7 |
Drives: 2011 IBM 1LT w white Rally Stripes Join Date: Aug 2012
Glad I wasn't the only one sweating over this. Though the first time I had a flat, that little air compressor did nothing but blow the fuse to the aux port on the car, so I threw the thing away and invested in a couple of cans of Fix a flat. Good to know a kit like this exists!
06-23-2017, 10:20 AM | #8 |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
Will this fit over zl1 brakes?
Sent from my VS995 using Tapatalk |
06-23-2017, 12:03 PM | #9 | |
However, my car doesn't have the "roller skates" on it as I don't have the factory brake pads anymore so I didn't really think of it. I wonder how many people actually have the "roller skates" on their car still though? It seems that most aftermarket brake pads don't have them. I don't see why anybody would want them |
06-23-2017, 12:06 PM | #10 | |
06-23-2017, 12:08 PM | #11 |
06-23-2017, 12:36 PM | #12 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
I bought my car brand new in November of 2015. It came with a spare and jack...
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
06-23-2017, 02:37 PM | #13 |
Are you sure that the spare isn't for a V6 camaro? Everything I've read on the forums said that GM has never made a spare for the SS. However, they did offer it for the V6 models without the Brembo's.
06-23-2017, 02:53 PM | #14 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
His is a V6 (LFX)
Tags |
2011 camaro spare tire kit, spare tire kit, spare tire kit ss |
Thread Tools | |
