11-16-2011, 09:48 AM | #1 |
TRI-COUNTY CAMARO... FTW!
Drives: 2010 Camaro 2SS M6 Cyber Grey Join Date: May 2010
No more decel pop.
Just curious.... after my cam, LT's, etc... I just realized I have no more decel pop. Do most tuners turn off the fuel cutoff with a cam? Sorry, just realized how much I loved the pop, more so now that its gone.
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
11-16-2011, 10:36 AM | #2 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
I was wandering the same thing. I assumed it was the overlap of the cam that messed it up
11-16-2011, 10:39 AM | #3 |
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
Idk... Cause mine seem to have gotten worse after my cam and tune... I actually asked my tuner to decrease it as much as possible... But it still does it.
Sent from my SCH-I510 using Tapatalk
11-16-2011, 10:44 AM | #4 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
You can have a very wild cam with tons of overlap, and if the decel fuel cutoff is disabled and the decel fuel AFR is tuned properly it won't have a single pop on decel. Which when modding for more airflow like with LTs, cam, heads... means adding a lot of fuel to the decel tuning. |
11-16-2011, 11:46 AM | #5 |
Drives: Fast Join Date: Feb 2010
OP, your tuner must have disabled DFCO.
http://www.youtube.com/watch?v=fPvVm...&feature=share
New and improved non-violation sig vid!! |
11-16-2011, 12:06 PM | #6 |
What is the DFCO? And can the tuner turn it back on easily?
Is it decel fuel cut off? lol
11-16-2011, 12:21 PM | #7 |
Drives: 2010 Camaro SS Join Date: Oct 2010
I noticed the same with my cam. No popping on deceleration. When checking DFCO (decel fuel cuto off) status in the dealer service tool (GDS2) it says it is enabled. I asked Livernois and they said it was enabled as well. So I'm inclined to believe it is there and working but it just behaves differently after the cam upgrade.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
11-16-2011, 01:16 PM | #8 |
Decal fuel cutoff (DFCO) gets disabled by some tuners. It can be minimized in the tune as well. My wife called me today after exhaust work and said "the poping is louder" I just told her, do you want it minimized or turned off??
11-16-2011, 01:34 PM | #9 |
Drives: VR 2010 Camaro SS/RS Join Date: Jul 2011
What is your idle set at compared to stock? Did your driving style change with the cam(for instance using the gears to slow all the way down or just coasting to a stop or any mix in between)? These can also be factors in whether or not you get decel popping.
11-16-2011, 02:05 PM | #10 | |
Idle is around 950 now... forgot what stock was....
11-16-2011, 02:51 PM | #11 |
Drives: 2015 c7 Join Date: Nov 2009
mine also has completely stopped. i do sometimes get a pop when shifting or if i tap the gas at idle. it has to be normal.
11-16-2011, 02:55 PM | #12 |
Drives: something faster than you Join Date: Aug 2010
I found that if you have fuel cut off while decellerating then it will be quiet, but if you don't it will burble and pop away. With the current exhaust setup I have, I love the sound it makes while decelerating at higm rpms, so I left the fuel on. With other exhaust setups I hated how it sounded, so I tuned in a more aggressive fuel cut off while decelerating.
So look like your tuner went and extended the fuel cut off, thus decreasing your pop. |
11-16-2011, 02:57 PM | #13 | |
11-16-2011, 02:58 PM | #14 | |
Similar Threads | ||||
Curious about decel fuel cut-off, AFM/DOD | f5journal | Tuning / Diagnostics -- engine and transmission | 8 | 07-09-2011 12:37 PM |
ATAK compared to Muffler delete, decel. popping? | defragme | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 07-24-2010 10:01 AM |
Decel Exhaust pop ?? | HDCrazy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 38 | 06-11-2010 12:21 PM |
Burnt Popcorn and an argument with Bonnie / Need an answer / Please help. | PQ | Off-topic Discussions | 108 | 01-28-2010 08:09 PM |
What my dealer said about tuning my car | Ripptide56 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 38 | 01-15-2010 10:52 PM |
