Old 03-16-2018, 04:38 PM   #1
Jiver11
Jiver11's Avatar
Drives: 2014 Chevrolet Camaro 1SS
JPSS Castor Lock and Camber/Castor Bolts?
I'm slightly confused on the install for these two options.
I originally thought that the JPSS castor locks were utilized in the front and JPSS Black Magic camber bolts in the rear.
Now after some research I'm wondering if these applications are only made for the front? Specifically where the radius arm mounts.
If someone could give me a breakdown I would greatly appreciate it, couldn't really find an answer when I was researching. I am lowering car on coilovers, about 1.5" all around.
Jiver11 is offline   Reply With Quote
Old 03-16-2018, 04:55 PM   #2
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
caster locks are stand alone original bolt is reused get radius arm inserts to swap in at the same time you have it apart to grind out the slot
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 03-16-2018, 05:24 PM   #3
Jiver11
Jiver11's Avatar
Have the radius arm inserts. If using castor lock why would you need to grind the slot? I understand with the castor bolt but if reusing original bolt with castor lock I wouldn’t think I would have to grind the slot?
Old 03-16-2018, 05:53 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Locks don’t require grinding. Just drill the new bolt location and install (in the front)...
-Don
747 RWHP 794 RWTQ
Old 03-16-2018, 07:30 PM   #5
Jiver11
Jiver11's Avatar
Perfect thanks!
Old 03-17-2018, 11:38 AM   #6
Jiver11
Jiver11's Avatar
So I got the slots made. The castor locks basically give you two static positions that you can use. I will probably take the castor bolts & camber bolt with me just in case I can’t get enough adjustment with the locks.
When grinding the slots I ran into an issue with my dremel and made one side slightly taller than anticipated. My radius arm can now move up and down (slightly) with the locks in place but not tightened down. Question I have is, when I torque the radius arm down, will those locks/bolts ever move on me under load? The play in the arm is probably a 1/4” at most.
Old 04-08-2018, 11:34 PM   #7
TWOFORTYZ
Drives: 2015 Camaro 1SS 6M
Yes. They will move when subjected with an abnormal amount of force on the axis of the free movement. Just like everything with slack in the suspension. Would I still run it? Yes. You could tack weld the lock plates in place if you are concerned with the movement. Shouldn't take more than a few minutes for an exhaust shop if they don't mind the liability.
Every S13 I've owned had the tension rod mounts settled fully back due to the repeated stress on the components. This is relative to the stock clearance around the hardware, maybe 1/16" at most. Either way, upon doing my first alignment to the cars I would always pull them forward and RE TORQUE to spec, and they would hold position until the cars hit an exceptionally nasty pot hole or a curb then they'd be back at the rear of the "slack" again. Basically, if you hit something hard enough to need or want an alignment inspection, the bolts will shift. I've aligned my personal cars too many times to count.
Now being that the slack is vertical and the stress on the radius rod is primarily horizontal, I wouldn't lose sleep over it. Tack weld the locks or run it and check after you hit something. You can also use marking paint pens to verify if it shifts.
TWOFORTYZ is offline   Reply With Quote
Old 04-09-2018, 10:09 PM   #8
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
If I remember correctly JPSS Caster Locks are aluminum. Last I checked you won't be able to tack weld aluminum to steel.
What you can do is run a weld bead on the portion of the slot that is to large to reduce the size then carefully regrind to get proper size. That's how I fixed my screw up when I installed mine.
With the loads applied to the front suspension the arm will move. Over time the slot will get larger and the bolt will wear and things will only get worse.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
Old 04-09-2018, 11:53 PM   #9
Synner
Drives: cars
I agree, I'd never run a suspension bolt with slop in it. Or else a heck of a lot of red loctite and insane torque values would be involved but not on something that saw a track. A hardened washer welded to a frame has been used in redneck repaired suspensions though. A simple workaround for aluminum to steel welding that would never work. You can also weld and redrill the frame when a welder knows what he's doing and doesn't burn a hole through what he's doing as he fills it in.
Old 04-12-2018, 06:37 AM   #10
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
1/4 inch is a fair bit I would take slack out by pushing up, then get a piece of keystock 5/16"?the length of plate,might do both sides for continuity place against and parrallel to the plates and get it welded as a bottom fence
Old 04-14-2018, 11:04 AM   #11
Jiver11
Jiver11's Avatar
Thanks for the info guys. I'm going to take a look at it this week and see if the castor plates have shifted at all. I torqued the bolt to the proper specs but I had a feeling under normal loading of the car that the plates and bolt could potentially shift vertical. If so, we will look at doing some welding to fix the issue.
