03-29-2014, 01:22 AM | #1 |
Need Help!!!!!!!
These lights have been on for a month now been driving the ss so really didn't mind it but now i need to know why these lights are on. Please if you guys can tell me and how do i fix it?
03-29-2014, 01:41 AM | #2 |
Taeng
I'm not sure whether this applies to the Camaro, but I had those same lights go on in my Toyota Sequoia. In my case, it turned out to be low brake fluid. Check to see if your brake fluid level is low.
03-29-2014, 02:31 AM | #3 |
Ok i will check that. Thanks i hope thats all it is.
03-29-2014, 05:39 AM | #4 |
Drives: 2011 Camaro SS/RS Join Date: Nov 2013
It the traction control.. the button is next to the cigarette lighter.... No its not a brake light
I installed a new gauge cluster and my connector was loose... I removed.. reseated .. and its good... There is also a know issue where the harness under the engine computer gets chaffed and causes the issue.. have you removed the console gauge cluster before? check your wires.. I also got a long start also when this happened. |
03-29-2014, 06:22 AM | #5 |
My question would be, do the tires break loose easily when you do a hard takeoff? If so, I would check the fuse(s).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
03-29-2014, 10:36 AM | #6 |
i have removed the whole dash when i did an interior swap
03-29-2014, 10:37 AM | #7 |
i double tap the traction button nothing happens
03-29-2014, 11:18 AM | #8 |
Drives: 2010 Camaro 2SS/RS Join Date: Feb 2014
I'm about 90% sure it's your wheel speed sensor. I have the same issue with my jeep if the ABS, Traction Control, and Stabilitrac Light on. Hook it up to a computer to find out for sure. The part should only be like 20 bucks
03-29-2014, 11:30 AM | #9 |
Drives: 2012 2ss 45th anniversary edition Join Date: Jun 2012
Are you getting a "service Stabilitrak" message too?
Sent from my iPad using Tapatalk
2012 2SS 45th with a few tasteful mods
03-29-2014, 08:08 PM | #10 |
yes i have that service stability light on message too
03-29-2014, 08:16 PM | #11 |
The "service stabilitrak" message can be many things. I think because the traction control feature is based off controlling the power to the wheels, any time you have a power affecting issue with the engine, you will get that error. For instance, a misfire detected will give the Stabilitrak error. So, you could have a lot of things that will show that error. I would recommend hooking up to a code reader to see the actual code. Might be as simple as a loose plug wire or maybe an injector not working.... Sent from my iPad using Tapatalk
03-29-2014, 10:30 PM | #12 |
Drives: 2014 SS Join Date: Jan 2014
Check your spark plugs. I was getting same errors when one was loose.
2014 SS Stainless Works Headers w/ high flow cats, Stainless Works Retro Chambered Exhaust, Jannety Tune, Hurst short throw, APEX catch can, Tampa Tunning Throttle Body, APEX/Gen5 LED fogs, CAI Intake system, Diode Dynamics LED's, ACS T4 Splitter
04-07-2014, 01:14 PM | #13 | |
Hooked it up to a computer and it gave me no codes. I think it could be what your talking about. But how do I know for sure.
