12-25-2010, 10:41 PM | #1 |
Drives: 2010 SS F1-D procharger, Join Date: Jul 2009
Fastlane twin pumps??
Any news on how this system works compared to LPE or ADM's setup?
12-26-2010, 10:11 AM | #2 |
Drives: 2ss Join Date: Oct 2009
i think they are the same
12-26-2010, 11:18 AM | #3 |
Drives: Anything I want Join Date: Oct 2008
ADM and LPE are close to the same.Our system comes with a new wiring harness with heavier gauge wire to supply proper current to the module and pumps.
I have a few vendors that have bought both Fastlanes and Ours,they stated that ours is clearly more complete kit. The instructions for ours is here - http://admperformance.com/categories...40&category=77 |
12-26-2010, 12:19 PM | #4 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
Without a question LPE and ADM is a better more complete set up! Lack of the Fuel Control Management with the fastlane leaves the Voltage and amps below specs for operating a twin pump.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
12-26-2010, 07:07 PM | #5 |
Drives: 2010 Camaro SS / 2006 CC Duramax Join Date: Aug 2009
I used the Fastlane system on a car and was able to make 710 rwhp before fuel pressure dropped below 50lbs. Changed the system out to the ADM and was able to make 740rwhp before the fuel pressure dropped back under 50lbs.
12-26-2010, 08:43 PM | #6 |
So what system is recommended for over 750rwhp dont want to spend 1000.00 and then having to change it up.. or should I just go with a return style?
12-26-2010, 09:01 PM | #7 |
go with our return style setup...good to 1000hp with 83lb injectors
what in gods creation are you building that makes so much power |
12-26-2010, 09:08 PM | #8 |
Right now Im installing a F-1d Procharger and I have the 85lbs injectors. but I will be building a forged bottom end 434 and I dont want to be changing fuel systems again.. Just trying to make the right choice on the fuel system.. Thanks Andy.
12-27-2010, 03:30 PM | #9 |
With the exception of the new billet stuff that has recently hit the market, its all factory GM 6.2L CTS-V parts. It is 100% plug and play. Weve done a half dozen or so, and it works flawlessly. I have never used the other vendors stuff so, I cant say wether or not theirs work as well. I would assume so, since they use the exact same parts, so Im sure they work perfect as well.
1) Fuel Pump GM Part # 19207949 2) Fuel cross over line GM Part # 92203244 3) FPDM GM Part # 25967325 4) Fuel sender for the opposite side (I dont remember the part number, but its the CTS-V unit) 5) FPDM Plug (Dont have the part number, but again, it is the plug that connects to the FPDM part # above) From there, all you need to do, is get the pigtail plug that connects to the float assy, about 3" of high pressure fuel injection line, 2 high pressure crimps, , and a few feet of wire, and your done. Its quite simple, and nowhere near as expensive, as you may think. You will be into the entire kit quite a bit less than 800 bucks. Let me know if you need the wiring pin outs, or any of the specific parts. I will be more than happy to email them to you. All you are doing, is converting your car over to the factory GM twin pump system out of the CTS-V. HTH |
12-27-2010, 03:38 PM | #10 |
With those injectors, you will want to DEFINATELY run an external regulator, that is capable of "Boost Reference". If not, you will be riding on the minimum pulse width of the injector, and will fight the proper tuning at idle. By refrencing, you can lower your base pressure, which helps immensley.
Also, you can also run that exact same GM kit, as a full return system. All you will need, is some extra line, and a fitting tapped into the hat. You will also need a regulator. You will need to do some other work as well, but just shoot me a PM, and I will let you know what to do. Personally, I would step up to the new Fore precision kit. I would not run the GM assembly. I dont feel you would have enough fuel. Although they work awesome, its been proven a hundred times over, that those small pumps cant handle that type of power. We've been running the larger Walbro 255's, in Corvettes for years, and even those, start to push the limits of flow capabilities at the 1000+rwhp level. Fore Precision is coming out with the triple that should just dominate the market. Their quality is second to none. |
12-27-2010, 04:41 PM | #11 |
So the CTS-V dual pump system from GM works fine at 600 rwhp and is less money than the after market pumps? Interesting. I will check this out.
Edelbrock E-Force
Stainless Works Lts Roto Fab CAI Magnaflow Street Cat-Back DOD Delete Forgestar F-14's and Pedders XA + PKG Custom grind cam from Cincy Speed ADM dual fuel pump ADM AF/Boost gauges FTI 3200 convertor Hurst shifter Cincy Speed Build and Tune 540rwhp |
12-27-2010, 05:07 PM | #12 |
Drives: 2010 SS with WAY TOO MANY MODS Join Date: Sep 2010
The new Fore triple hat is amazing. Here's another PRI release that sounds unbelievably promising! Aeromotive is releasing their new Stealth 340 pumps for IN TANK replacements. 30% more flow across the pressure range and has the same body diameter as the Walbros so it bolts right into the Fore precision kits! 3 of these and the Fore billet hat and that 1000 should be pretty easy!
Aeromotive is also releasing a new submersible A1000 "drop in" for the Camaro saddle tanks too for the guys that want to make real BIG power. But for a street car the new Stealth 340's should be super quiet and actually work like a stock pump (turbine style) not a gerotor pump like the Walbro pumps. http://chevyhardcore.com/news/pri-20...lth-fuel-pump/ Each pump should be less than $175 retail! |
12-27-2010, 05:07 PM | #13 |
whats the ETA on the Fore Precision pump
12-27-2010, 06:35 PM | #14 |
I got off work and went straight to my dealer to price the cts-v dual pump set up and this is what I found
Pump. $540 Crossover line $15 Fuel sender opp side of tank $115 Wiring harness $143 Leveling sensor $147 Not sure how this is cheaper than $800 but I'm open to suggestions.
Edelbrock E-Force
Similar Threads | ||||
Fastlane Pipeline Cold Air Intake at Phastek Performance | Jason@Phastek | V8 Bolt-Ons & Tunes | 2 | 03-30-2016 07:19 AM |
Singe Turbo 2010 Camaro with 658 RWHP, 771 TRQ Built by Fastlane. | Fastlane | Forced Induction - V8 | 63 | 07-09-2014 11:11 AM |
Granatelli / Turbo Tech Twin Bottom Mount Turbo Systems | Granatelli | Forced Induction | 20 | 11-30-2010 06:47 PM |
Fastlane Pipeline Now $429 with Free Shipping @ Phastek Performance | Jason@Phastek | V8 Bolt-Ons & Tunes | 5 | 02-16-2010 07:50 PM |
