08-23-2016, 08:31 PM | #1 |
Drives: 2015 Camaro 1SS RS Join Date: Feb 2015
Couldn't remove oil filter
Changed the oil yesterday and the oil filter would not budge. The dealer did the last oil change and must of cranked it on. I first tried this
But that striped the bottom of the filter. Then I tried this and that started to bend the filter because I couldn't get the band closer to the base of the filter because the handle was too big. I kept trying, going really slow (trying not to rip it open), it finally broke loose. Damn dealer !! Is there a better tool to use to remove stuck oil filters (besides sticking a screw driver right through lol) ?
2015 Camaro 1SS/RS Blue Velvet Metallic, L99, Airaid Intake Tube, Akebono Ceramic Brake Pads, Borla S-Type Axle Back, GM Strut Tower Brace, Range Device
08-23-2016, 08:33 PM | #2 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
Exactly the same thing happened to me. Bought the same tool, same result as you.
I had to mangle the old filter to remove it. With a screwdriver.
08-23-2016, 08:38 PM | #3 |
Camaro: A Legend Reborn!!
It happened to me a couple months ago, I ended up using this it finally broke loose after the filter was pretty mangled.
[SIGPIC][/SIGPIC] |
08-23-2016, 08:45 PM | #4 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Heck, in the old days we'd just get a big screwdriver, drive it right through the oil filter and then use it as a t-wrench to remove stubborn filters.
08-23-2016, 08:49 PM | #5 |
I think the metal was thicker then. I did that and this thing was beer can thin. I ended up tearing most of the metal with the screwdriver stab. The other thing is clearance is an issue as the filter is recessed in there.
[SIGPIC][/SIGPIC] |
08-23-2016, 09:06 PM | #6 |
El Duderino
Sucks. Should only be slightly more than hand tight anyway. I have had luck with stubborn ones by using an oil filter wrench near the base of the filter if you can get to it. Other than that, mangle away is about your only other option...
My V6 has a cartridge type filter that I like as it's easy to get to up top and easy to replace.
I bowl. Drive around. The occasional acid flashback.
08-23-2016, 09:12 PM | #7 |
Just realized I have one of these too. Not sure if it would of helped though..
08-23-2016, 09:31 PM | #8 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Same thing happened to me last month, I used a 6" screw driver. It worked.
08-23-2016, 09:33 PM | #9 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
I have one of these...works great for those filters installed by the Incredible Hulk.
http://www.lislecorp.com/divisions/p...s/?product=379
NY5thgen.com
08-23-2016, 10:19 PM | #10 |
USA-1
Try some large channel locks...
08-23-2016, 11:07 PM | #11 |
Drives: 2014 2SS/RS Join Date: Dec 2014
You really need a different oil filter strap wrench; mine has a swivel handle that swings down for clearance ... when the strap is positioned so it is near the filter base plate it will not deform the filter canister when turned. All my vehicles have tight clearance around the filter base and this type swivel handle works great (the red part of the handle swivels 90 degrees up or down).
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
08-23-2016, 11:27 PM | #12 |
Drives: Miss Con Ception Join Date: Aug 2016
Using that band clamp near the end of the filter you can keep some pressure on it with one hand and tap the handle with a hammer. The impacts will cause a vibration which can cause the parts to loosen.
08-24-2016, 12:01 AM | #13 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
08-24-2016, 02:45 AM | #14 | |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Don M
Supercharged LGX + 6 speed manual = FUN!! |
