08-15-2013, 04:43 PM | #1 |
Drives: 2013 AGM 2SS/RS 1LE Join Date: Apr 2010
CAI Intake Installation Help
I'm currently trying to install a CAI Inc. Intake on my SS and it's all installed according to the directions, but I can't get the lid positioned to lock the fasteners on.
I know part of it should sit inside the groove but the lid still sits 0.5 cm too far up to fasten the two top fasteners, not sure if anyone else had this problem, maybe I did something wrong during installation, but not sure. |
08-15-2013, 05:33 PM | #2 |
Loosen the the nuts/bolts that hold the air box in place, then secure the lid with everything loose and everything should kind of fall into place. Once you have done that, carefully remove the lid without moving things around too much and re-tighten down the box.
Best regards, Tyler 888-308-6007 |
08-15-2013, 06:38 PM | #3 |
Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
They can be a REAL BITCH fitting it on the first time.
Try Tyler's suggestion.
2016 Hyper Blue 2SS |
08-15-2013, 08:52 PM | #4 |
Drives: 13' Sw 2ss Ls3 Join Date: Dec 2012
If u have the box bolted down to far forward by the 10 mm nut inside it it will b a pain loosen and slide the airbox a bit and retighten should help
08-17-2013, 03:38 PM | #5 |
Drives: 2013 Chevy Camaro SS 1LE Join Date: Aug 2013
When I put mine in it was a pain to. I had to push min back towards the firewall a little to get it so i could slip the lid on.
Thread Tools | |
