08-08-2015, 03:37 PM | #1 |
Drives: 2010 2SS/RS Join Date: Jul 2014
Anyone have issues installing ridetech endlinks?
Installed a new set of ridetech coilovers yesterday and was getting a clunk in the front. Traced it back to a loose connection on both sides between the endlink and sway bar. Went to tighten them up a bit and the nut just spun on the threads. Went to the other side and same thing. Tried a wrench, then a socket, then an impact gun and finally had to bring it to the shop where they ended up cutting them off.
Has anyone ever had issues trying to tighten these down before? I am running a BMR swaybar up front which has the 12mm holes so was using the supplied washers ridetech gives you fr their 10mm studs to work in this application. Need to get the swaybar hooked back up. Otherwise these coilovers are awesome!
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs.... Use to have 2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's |
08-08-2015, 06:05 PM | #2 |
aerosportconcepts@gmail
Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Did you use two wrenches. Need to hold the inner with a thin wrench or the outside nut will just spin the stud too
Thank you Kurt Robinson Aero Sport Concepts
08-08-2015, 06:28 PM | #3 | |
The attachment to the shock body was fine, that torqued down perfect.
Current car
08-10-2015, 12:41 PM | #4 | |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
All The Best Orange 2010 Camaro |
11-19-2015, 09:41 AM | #5 |
Drives: 2013 Summit White Camaro 2SS RS 1LE Join Date: Oct 2012
Not sure if you ever got this issue resolved. If you have a 1LE with 12mm sway bar holes or an aftermarket sway bar with 12mm, the washer system they supply doesn't work perfectly. I initially tried using the supplied washers, but we were constantly hearing metal on metal rubbing from the front. The problem is that you can't get everything tight enough because the washer can only hold so much torque. We even tightened it with our full body weight and it still moved around. Eventually the washer started to become concave with how tight we made it.
I tried to find some endlinks that had a 12mm stud on one end and 10mm on the other (attached to the coilover) and I couldn't find a single thing. So we took the stock 1LE endlinks (both studs are 12mm) and cut out a center section of the rod, welded it back up and put a large metal sleeve around the weld to keep it from breaking. Had to do all that to make it shorter like the Ridetech endlinks since the mounting point on the coilover is closer to the sway bar. And then we drilled out the 10mm hole on the coilover to 12mm. Everything worked after that and no more squeaking. If Ridetech could offer some endlinks with one 10mm stud and one 12mm stud, that would be the best solution. |
11-20-2015, 09:45 AM | #6 |
Drives: Race Car Join Date: Sep 2009
