02-27-2016, 05:08 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Is there a garage DIY way to change a fuel pump?
I've got a ZL1 pump that I need to get dropped into my tank. I'm wondering if there is a way to get this done in my garage with jacks and jack stands? I think the answer is no...because if I'm not mistaken the entire rear cradle needs to be dropped to get at the fuel pump?
I know the method of cutting a hole in the floor under my rear seat. And I really have no problems with doing this. It seems like a good way to provide ongoing access to the pump in case I need to get at it again. But before I do this, I wanted to check if I was missing something and there was another way to change the pump for a garage warrior.... |
02-27-2016, 05:11 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
The first time I dropped the cradle. The second time I cut a hole. Those are the only two ways to get to the fuel pump.
If you drop the cradle, follow the directions for installing subframe bushings to get the cradle lowered. Then you just have to undo some lines and electrical connectors and the tank straps to get it out. Either way you decide to do it, run it low on gas or siphon it out before you go about it. |
02-27-2016, 05:31 PM | #3 |
Thanks for that post. Yeah I'm really trying hard to find the logic in not just cutting an access hole in the floor under the rear seat...
02-27-2016, 06:30 PM | #4 |
I know I am keeping my car to pass on to my kids so I wasn't concerned about it. There are a couple of threads on here that show the placement of the hole. I bought an access panel
http://www.jegs.com/i/Allstar-Perfor...ductId=1625086 to put over it. If you cut a hole, start at the passenger rear corner. It gets extremely tight at the driver's front corner and there is almost no room for error. I actually scored my tank in that area. I reached inside and nothing came through and it felt solid from inside so I just filled it with some plastic JB Weld stuff. |
02-27-2016, 06:57 PM | #5 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Cut the access hole, it's easy. Should have been like that from the factory
02-27-2016, 07:12 PM | #6 |
Drives: 2010 ss/rs Join Date: Jun 2013
cut the hole and make sure to replace the gasket.
rotofab cai
ported throttle body sp headers with cats loud mouth axle back no mufflers tuned by steve williams 6l80etuning.com bmr split springs cam motion custom camshaft btr 660 spring kit maggie 2300 id850 injectors livernois fuel pump |
02-27-2016, 07:28 PM | #7 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
You will probably need the special tool to get the ring off. You can use a screwdriver and hammer but its a lot easier with the tool
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
02-27-2016, 07:56 PM | #8 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Just did it yesterday. Lowered the front of the cradle, didn't have to drop it all the way but I have a lift. No issues using a hammer and screwdriver. Literally took a couple soft taps off and back on
02-28-2016, 09:19 PM | #9 | |
02-28-2016, 09:20 PM | #10 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
Sub'd
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
02-28-2016, 11:32 PM | #11 |
Here ya go.
I used some weatherstripping to help seal (it's out of place in the pic). The rubber grommet for wires still fits in the hole next to it as well. I don't have any pics of it in place though. There is no rivet in the one corner because it's too tight against the tank. |
02-29-2016, 12:29 AM | #12 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
I done mine on jack stands.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
02-29-2016, 08:36 AM | #13 | |
