07-02-2014, 11:39 AM | #1 |
Drives: 2010 White 2SS m6 Join Date: Jul 2012
Pushrod Length Question
I am in the middle of installing a night fur cam on my ls3 and I ordered 7.425 rods but i measured and actually nee 7.375 which is the exact length of the stock ones i pulled out. would it be alright to re use the stock push rods rather than order and wait for hardened 7.375's?
thanks
Corsa Cb, RX catch, Vararam, LT Headers catless, slowhawk tuned, 20% tint, hks1inch lowering springs, zl1 20x11 wheels, nt05's, aac side-markers, more comingl ...
07-03-2014, 12:17 PM | #2 |
Drives: 2011 LS3 Join Date: Jan 2012
I used 7.425 in mine.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
07-03-2014, 12:25 PM | #3 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
Do not use the stock push rods for an after market cam. I believe Lethal Racing recommends the 7.425" length for the LS3.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts Last edited by BenningJ; 07-04-2014 at 11:34 AM. Reason: Fixed: 7.400" to 7.425". Removed misinformation. |
07-03-2014, 01:05 PM | #4 |
I was told 7.40 is too short unless your heads are milled. And that 7.425 would be better choice cuz it would have a better preload on the valvetrain over the shorter 7.40.
07-03-2014, 02:06 PM | #5 |
Thanks guys, also do I have to put each cylnder into top dead center firing position in order to re install the rockers and the proper tourqe
07-03-2014, 03:29 PM | #6 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Yes, better to not be fighting the springs while torquing them down.
07-03-2014, 08:26 PM | #7 |
they recommend 7.425 for ls3 and 7.400 for l99. did you add in the preload when you measured. preload of .060-.075
07-04-2014, 11:33 AM | #8 |
7.425" is correct. Not sure why I was thinking 7.400" for the LS3.
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
Tags |
cam, nightfury, push |
