02-28-2014, 07:29 AM | #1 |
Drives: 2010 Camaro 2ss black 21's Join Date: May 2012
what is needed for diff swap in l99
I am hoping to do a diff swap in my 2010 l99. I need to know what I am going to need to do the swap. Do I need new driveshaft bolts? And what else would I need?
Thanks in advance. |
02-28-2014, 08:32 AM | #2 |
To be safe, I'd replace your drive shaft, upper control arm, trailing arm and toe rod bolts. There all TTY type bolts. Other than that, just diff fluid. It's a simple swap really. Oh yea, replace the axle seals on the diff if there not new.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
02-28-2014, 09:45 PM | #3 |
Drives: 2010 2SS/RS Centennial Indy edition Join Date: Dec 2013
I am also about to swap diffs. I am going from my l99 to a 1le will my driveshaft bolt up without modifying it?
02-28-2014, 10:41 PM | #4 |
Yes. Direct bolt in then recalibrate the tune for the new gear ratio.
03-01-2014, 12:45 AM | #5 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Yes, reguardless of whats inside, the casing is the same, so everything will line up just fine. If you changed the tranny, thats when the DS wouldnt fit.
2010 Camaro SS LS3 - No Modz
Thread Tools | |
