Old 09-26-2013, 12:33 PM   #1
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
Tool sizes for drive shaft?
Anybody know exactly what tool/type sizes for removal of the drive shaft to that rubber damper to output shaft? Dropping my tranny later. Need to know what size to get so I dont have to buy a thousand tools.. Looks like a torx bit and maybe a torx socket or something? Doesn't look like a 12 point will fit on one of the bolts reliably.
Thx!!
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 09-26-2013, 04:43 PM   #2
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
They're external torx bolts. Go to Sears and buy Craftsman new Universal wrenches. I paid $50 for a metric set and they're great to have around. They'll hold the bolts.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 09-27-2013, 11:04 PM   #3
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
A 6 point fits well enough. I think they're only set to about 80 ft lbs. Can't remember what size.. Either 18 or 21 mm pretty sure.
K32 Camaro is offline   Reply With Quote
Old 09-28-2013, 08:42 AM   #4
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Buy the correct, properly sized tool. If you have a Harbor Freight in your area, an entire set of the correct sockets will cost less than one wrench from Sears. I choose not to ever use 'universal' wrenches as there's too much chance of slippage that can/will mess up a fastener.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
